View Full Version : Engine EFI Mgt system and harness for a Gen V LT1
I've been on a hiatus from the PT deal for a couple of years while I was focusing on SCCA racing. Now I'm down to 1 race car, 1 Camaro and looking to get this 69 Camaro finished.
I just picked up a Gen V Lt1 dry sump engine with 27k miles and will be in need of a engine mgt system for the efi etc...
Looks like the same names are in the game, Holley, Fast, stock & more. Something relatively new I see is the self tune features available.
My plans are to stick to NA. Heads ported, cam, remove AFM, MSD or ported LS2 intake, bigger TB and a good tune should net me 500-550 BHP through a T56 magnum close ratio.
In full disclosure I don't know jack about tuning an engine through EFI but willing to learn or pay someone if need be.
So in this sea of engine management options, any comments, experiences and recommendations?
btmatt
09-16-2022, 05:07 AM
find reputable tuner in your area and get his recommendation since you will probably have to rely on him at some point to meet your goals.
full disclosure we 4 cars using 4 different systems that have been tuned at some point: Stock Z06, Megasquirt LS3, Holley LY6, and ProEFI stroker 408/Turbo
ryeguy2006a
09-16-2022, 05:08 AM
There is a Terminator X Max out there that will control Gen5 DI motors. I'd give Andrew a call and talk through it with him.
csouth
09-16-2022, 06:27 AM
I'd check Speartech if you look to stay stock.
Definitely a consideration and solid option. I do have a possibility of picking up a PSI harness and ECU for 1200 bucks. Stock tune.
seems reasonable till I have to tune it with the new cam, intake & TB.
i watched this guys install last night. Looks like a complete system. Expensive for Holley though. They are real proud of it at $2800. I’ve had their old commander system on my boat 540 in the mid 2000’s. Their wire work was kinda crappy back then. Bad pins crimps & pinched wires mid harness.
https://youtu.be/ZLj0x-6uL0o
- - - Updated - - -
know anyone around Phoenix? I think I know of a guy in Havasu that does Fast systems in boats.
csouth
09-18-2022, 06:25 PM
I got my harness, ecu and pedal from Speartech for about $1500 and it was setup with base tune using cam and injector specs that I provided.
Bthomas
09-18-2022, 08:03 PM
For gen V id go gm ecu and hptuners or efilive. Also plan on paying a decent amount to get a good tuner.
btmatt
09-19-2022, 07:00 AM
ProEFI is in Glendale; Kurt Siebels has been a huge help to me
Great info guys! Thx for your help and input!
Consensus is stick to the GM Op system and have a company like spear tech build the harness. ECU's seem pretty reasonable from what I've seen online. Depends on what way I go with the engine I can probably get a damn near close tune from a builder. At least get me running till I get to a refinement tuner.
Looking at options. Maybe a stoker kit. Would like to sleeve it and do a 427. Just love the idea of it. I'm getting the drive train mocked up, accessories, oil & cooling systems mocked up before before I finish the cage and send for body work.
Cheers!
