View Full Version : Upgraded GM A Body Frames (Not full Pro-Touring Chassis)
danstorm801
07-10-2022, 10:43 AM
Pulling my '67 Chevelle out of mothballs and will be working on an LS Swap / major suspension upgrade with my 2 boys. The car will be a driver that I also want to handle well on some twisty mountain roads or maybe an autox 2-3 times a year. No intention of heavy trackday use.
So I'm looking for an upgraded chassis that comes with upgraded performance without going to a full RS, Speedtech, Schwartz, etc. setup.
Here's the question: Is there a reputable company that will take your stock frame and box / brace it, and other upgrades to accomplish what i'm looking for?
csouth
07-10-2022, 11:17 AM
There are no companies per 'se offering this a s a service. You would have to find a shop to do that for you. Ideally having a spare chassis or having yours removed would help you facilitate things. By the time you pay for labor and buy upgraded suspension components you would probably be in the neighborhood of and RS Spec chassis.
NorCal-SS
07-10-2022, 11:26 AM
Hey sounds like we’re in similar situations. I’m finally getting around to building my 67 Chevelle after it sat for almost a decade. Last year I had a local fab shop weld in the Hellwig FrameFX kit onto my factory frame. I haven’t driven the car since,but it looks and feels way more solid than before. If you have a welder and a way to lift the body it wouldn’t be too hard to DIY. Might be worth a look. And good luck!
danstorm801
07-10-2022, 12:02 PM
Thanks guys, makes sense. Was wondering if there was a "go to" company or shop for this type of thing.
Dslpwr
07-10-2022, 04:25 PM
I’m in the same boat 64 ElCamino, by the time I do the frame over and do the suspension I think the speed tech chassis is the way I’m going.200883
danstorm801
07-10-2022, 05:26 PM
Great looking car. Knowing I’ll probably end up down this rabbit hole… what is pointing you toward the Speed Tech vs. others?
232_ray
07-10-2022, 07:22 PM
Speedtech chassis is amazing. Haven’t driven mine yet but I would buy their chassis again! As a matter of fact I just bought their extreme chassis for my
‘70 Cuda also.
Hotwire
07-11-2022, 04:56 AM
I'd call the mfgs of the boxing kits, if they don't do the work, they may sell to shops that do.
http://www.abcperformance.net
https://www.hellwigproducts.com/products/?partnumber=11102
You could find a fab, welding, or frame shop in your area that could handle the work.
You don't necessarily need to box the frame to have fun with them, unless you're just wanting to spend money? You could find a convertible frame that's already boxed from the factory. Make sure your body bushings are in good shape and all the sheetmetal bolts are in place as they're all meant to work together as a system.
I'm running a front frame brace (highly recommend), rear control arm braces (made a difference), and complete aftermarket suspension that I put together on a budget and am having a lot of fun with it. Boxing the frame is on the list but can be done down the road.
https://static1.pt-content.com/images/pt/2022/07/52030600457_27bde824c1_c-1.jpg[/url]
raustinss
07-11-2022, 01:35 PM
I agree any local custom car shop or fab shop should be able to fit your needs using the stock frame , a front frame brace , summit aka hpi frame brace kit and abc performance mini tub kit will make significant changes in how your car feels and suspension works . Most of all its way cheaper than an aftermarket frame
Dslpwr
07-11-2022, 04:15 PM
Just looking at all the the different venders of chassis the torque tube rear suspension make me think the car will ride and handle better.
vcho455
07-12-2022, 04:42 AM
Where are you located? This guy has been doing A-body frames for quite a while now.
https://portland.craigslist.org/clc/pts/d/oregon-city-chevelle-malibu-wagon-el/7494767622.html
danstorm801
07-12-2022, 06:39 AM
This is exactly what I was thinking. Thanks!
chevelletiger
07-12-2022, 06:35 PM
I make front chassis braces,and just came out with a mid lateral supports brace that bolt in front of the lower control arm mount.
They make a huge difference in chassis rigidity.
And don't fool yourself,! Lol.
Once you and your boys start doing autocross events you'll get hooked.
Let me know and we can make you a set of braces.
Also if you going with a stock spindle tall ball joint are a must.
I could do the fab work on your stock chassis,
I'm in socal. I do alot of side car work at my home,so I have no over head and prices are very fair.
67-LS1
07-13-2022, 12:34 PM
Jim’s Chevelle Alley will do what your looking for. They have been for years. They’ll modify your frame, sell one outright or exchange.
They will do pretty much anything you want, ie, boxing, narrowing, powder coating, upgraded suspension, brakes, you name it.
They also may pickup and deliver depending on where you are.
https://jimschevellealleyllc.com/
Twentyover
07-23-2022, 08:25 AM
I believe the frame pictured is to one I sold when I aborted a 65 elCamino project. Has narrowed rear frame rails and a frame stiffner kit from some guys up in Canada. The car was located in Portland , I was located in Michigan, and enthusiasm ran out when every panel on the car except the roof was bent. Still have most of the suspension bit fosr it and an LS2 that are slowly being cannabalised for other projects
Vortexgen1
12-03-2022, 11:39 AM
Chevelletiger, are you still making the front frame braces? I have a 64 GTO and was looking to stiffen up the front of my car. I have added the UMI bar under the sway bar, but would like more. It looks like you made the braces for the 68-72 A-bodies. I saw the price at $195 + shipping, awhile back. I know everything has gone up. You also said something about a mid brace around the control arms well. I have the SPC front upper and lower control arms and a rack and pinion steering and would be interested in that as well if it would fit. I was looking at the front frame brace from SCandC, but they are no longer online.
Hotel Charlie 69
04-08-2023, 09:17 AM
I am looking for bracing on my Chevelle also. What did you end up going with?
chevelletiger
04-11-2023, 05:52 AM
I still make the front brace,but only for 68-72 ,I still haven't had the time to get together with one chevelles.com member that was going to bring over his 66 so I could male one,and the jig.
Price went up to $200.00 plus shipping.
Material cost went up on tube.
Mark at sc&c went under.
It's ashame
Vortexgen1
04-29-2023, 02:45 PM
Chevelletiger, I will keep checking back to see if and when you have the front braces ready to go in the future. I am still very interested in buying one from you.
Charlie_in_OC
04-29-2023, 04:34 PM
[QUOTE=I still haven't had the time to get together with one chevelles.com member that was going to bring over his 66 so I could male one,and the jig.
[/QUOTE]
I have a bare 1965 El Camino frame that I'm working on to do a frame swap on a 1964 Buick Skylark wagon in Fountain Valley 92708 if you're ever down in Orange County
pitts64
08-23-2023, 04:07 AM
The el Camino has a fully boxed frame, it comes from the factory like that. Its called the A.O. Smith #1941.
raustinss
08-23-2023, 12:56 PM
Correct but.... the el caminos have a longer wheelbase than the 2 door chevelles
Charlie_in_OC
08-24-2023, 04:29 AM
64-67 GM A bodies and 68-72 GM A bodies have different frame dimensions, Frame #1941 isn't listed until 1968 and OP has a 1967.
https://chevellestuff.net/qd/frames.htm
pitts64
09-01-2023, 06:40 AM
I get my info from the GM Heritage Site... https://www.gm.com/heritage/archive/vehicle-information-kits
416velle
10-17-2023, 09:29 AM
The greatest thing you can possibly do in the garage is find someone to teach you to mig weld. HIGHLY HIGHLY HIGHLY recommend it. Because it opens the doors for so many more things big and small that you can do yourself to not have to rely on shops that take forever and/or don't do great work. You can do the frame box yourself, rust repairs, dumb little brackets and mounts so you don't have to thru-bolt everything, its definitely a life changing skill for sure.
FWIW I have a HPI customs frame kit (similar idea to the speedtech one) on my chevelle....I have some suspension stuff from ABC performance and Tony there said after some frame torsion testing, all you need to make a significant difference is a simple box (they sell it, its attractively priced too). So if I were to do my frame over again, I definitely would've done the ABC kit and negated some 40+lbs from the HPI. I have a 6pt roll bar on my rig so the ABC definitely would've sufficed.
If you want to just handle well, you don't really "need" hardly anything, my chevelle handled well before I ever had frame stiffening, a 3 link, big sway bars, or coilovers. It performed dead in the middle of the pack at LSFest for 3 years. If you want to be competitive in autocross, that's a different story, because chevelles take a LOT to be 'fast'. Ask me how I know :D
cmurda8
11-20-2023, 05:48 PM
Chevelletiger,
I would like to purchase one of your front and rear 68-72 Frame Braces. I've got an HPI Frame Brace kit on order that should be shipped this week. I think your braces will compliment their kit and give me what I am looking for. Hopefully the rear clears my 3" exhaust and the front will clear my RideTech MuscleBar...I saw that chuckd71 thinks it does in your Classifieds post. Unfortunately I don't have credentials to post the link or reply to classifieds.
I'm in the Bay Area, so I might just pickup when I'm down south.
I'm a Lifetime member on Team Chevelle (chevelles dot com) and sent you a PM from there too. I don't have enough posts to PM you here either.
Look forward to connecting with you. Thanks!
Fiestacruiser
03-07-2024, 04:59 PM
Hi chevelletiger, I’m interested in having some frame work done
Fiestacruiser
03-20-2024, 09:15 AM
Will the El Camino frame bolt up to the Sportwagon without modification to the mounting points? I have a vista cruiser and was wondering if they’re the same
ProTouring442
03-20-2024, 12:28 PM
No. The wheelbase on an ElCamino is 116" while the wheelbase on the Vista Cruiser/Sport Wagon is 121".
minni
09-15-2025, 10:28 PM
I would like to purchase one of your braces please send me a DM.
