View Full Version : Trutrac axle spacer
Titan1021
07-09-2022, 02:20 PM
​Fellas need some help with a new trutrac diff. I was finishing a rear ended rebuild and the axle spacer was a bit tight. So I had the great idea to tap it into place. My question is is there any side effects to having the axle spacer to tight against the axle shaft. Other then the obvious I can’t pull it out. Thanks.
eaton Trutrac diff
chevy 10 bolt 8.5
new moser axle shafts.
