View Full Version : Wiring Relay for NSS with Brakes and Switch
Mr Nick
07-04-2022, 07:19 PM
Ever since I did the manual swap (69 Oldsmobile Cutlass), I've been using a simple momentary toggle switch zip tied to the column for my ignition NSS. I'd like to finally make it a bit nicer.
I'd like to wire in a relay in such a way that the brakes need to be applied and a small momentary button depressed.
Is this correct?
30 - Factory purple ignition wire
87 - Factory purple ignition wire
86 - Tap into brake light switch
85 - Momentary switch to ground
Hotwire
07-05-2022, 07:22 AM
Yessir, that will render the starter kill disabled until the switch and brake pedal are active.
Mr Nick
07-06-2022, 04:01 AM
Thank you, Jeff.
Hotwire
07-06-2022, 04:18 AM
You're welcome.
I'd put a brake switch into the stop of my clutch pedal and use it as my safety. Car won't start unless clutch is pushed in.
Think it was an 3/8" hole and used an 80s S10 brake switch, spring metal cage to hold it in place, along with relay like you're thinking. Have a t56 and an using tilton 75 master.
dontlifttoshift
07-06-2022, 05:12 AM
Why not the factory clutch switch that mounts on the pedal?
Hotwire
07-06-2022, 05:42 AM
Hey Donny, could you elaborate?
This is my setup, used the switch for my P59 ECM, works as starter enable as well as cruise control disable.
https://static1.pt-content.com/images/pt/2022/07/52198188619_65d4de2ac9_c-1.jpg
dontlifttoshift
07-06-2022, 12:03 PM
Jeff, I have done them like yours before. When there is a factory switch available for that make and model, it is a lot easier. So for Nick's cutlass, I would just buy the factory switch and install it.
https://www.thepartsplaceinc.com/product/1969/1969-oldsmobile-cutlass-442-f85-clutch-pedal-neutral-safety-start-lever-switch/67636
200831
Mr Nick
07-07-2022, 10:39 AM
My clutch pedal arm has been modified and I'm not sure it would work with a factory item.
200844
