View Full Version : GM A-body shock angle question
Hillard
06-22-2022, 06:22 PM
The rear shocks on a 69 GM A-body are tilted inward at the top. For a Pro-Touring application is it best to leave it alone? I want to use coilovers and I can modify it to put the shocks wherever I want.
marolf101x
06-23-2022, 06:09 AM
There's no simple answer other than don't lean them more than 25-degrees, as there are theories as to which is better, angled or straight up and down.
DSE typically place them straight up and down.
Ridetech typically angles them around 15-degrees. We did this for packaging and added wheel travel.
The more angle they have, the less effective they are, but the wheel travels slightly more. So I typically upped the spring rate and shock force accordingly (which really wasn't much).
Get the lower mounting point as far out as you can.
Hillard
06-23-2022, 12:01 PM
Good information. Thank you! I've always been a drag racer and we like them straight up and down. Of course we don't care about turning. I'm building my first Pro-Touring car and learning how to make one handle. I thought maybe angled was a little better, but I was guessing.
