View Full Version : II Much VSB Vent in a 69 Camaro stock floor pan location?
jorgezee1
06-20-2022, 01:19 PM
Looking to see if anyone has installed the IIMUCH VSB vent setup on a stock rear trunk pan?
I bought the VSB a couple years ago and now thinking I should order the VSR. Is mounting anywhere in the Camaro trunk OK or does it need to be at the highest point in the trunk? Has anyone installed or used the VSB on the right or left side of the frame rails by the tail lights on the stock trunk floor?
dhutton
06-20-2022, 01:35 PM
Needs to be high with no dips in the hose. I would give them a call.
Don
jorgezee1
06-20-2022, 01:53 PM
Don
Thanks Don.
Called John and and looks like I will just make a plate for the VSB and mount it somewhere above the trunk pan. Installation would be similar to the VSR at this point. Looks like he is about 5-6 week out of stock for VSR or VSB units, so I will move forward with making a bracket.
Thanks!
jorgezee1
06-21-2022, 05:07 AM
Looks like I am going to be into about 100 - 150 in fittings. Anybody have part numbers to fittings they used for their VSR setup?
I am looking at running the Vapor Guard hose and fittings. For the Vent system this seems to be more than adequate. Also I was having a hard time finding a female ORB -6 bulkhead fitting. II Much has a really nice double female bulkhead piece I might order but wanted to see if anyone else went through this and has a recommendation?
Also I am running a ricks stamp steel tank. It appears they use a quick connect fitting for the vent. I will call them and ask. I will post it with some pics once I have all the parts. Hopefully it will help the next guy try to do this.
dhutton
06-21-2022, 05:36 AM
You could possibly run the hoses through grommets and avoid the bulkhead fittings. I know these fittings really add up.
Don
