View Full Version : Suggestions for undercar finish
arcane73
06-18-2022, 02:02 PM
Hi everyone,
I've recently completed replacing the floors and part of the tunnel in my car. I scuffed everything up and sprayed uPol's epoxy primer on everything. https://u-pol.com/en-us/product/coatings/primers/raptor-41-anti-corrosive-epoxy-primer-kit
The inside of the car will be getting lizardskin heat and sound control. What should I do with the underside of the car? I am thinking that I will at least spray the heat control directly under the seat pans but I'm looking for suggestions for the rest of the freshly primered areas.
ARAD RS
06-18-2022, 03:04 PM
Hi There,
I recently shot U-Pol Raptor on my under carriage and Lizard Skin in the entire cab.
Everything looks super Fantastic.
If I need additional sound deadening or thermal barrier in the interior I can always lay down some dynamat.
79 Camaro
06-19-2022, 01:03 PM
On my projects I degrease first. Scuff. Eastwood primer as needed. Then Eastwood chassis black. Then just spray bomb under coating.
arcane73
06-19-2022, 04:41 PM
I ended up ordering the raptor liner in light grey.
I sprayed southern polyurethanes epoxy and upol black on my camaro, I think it turned out great
I also plan on spraying lizardskin in my car, can you provide pictures of what it looks like? I am interested in seeing
200573200574
arcane73
06-19-2022, 08:35 PM
This is the only one i have at the moment. It's not the best pic. This is the Sound Control. I'll be spraying the ceramic insulation next weekend.
https://static1.pt-content.com/images/pt/2022/06/gsk892g-1.jpg
arcane73
06-25-2022, 05:20 PM
This was after both coats of both the LizardSkin heat and sound control were done.
https://static1.pt-content.com/images/pt/2022/06/JRpnCaUl-1.jpg
https://static1.pt-content.com/images/pt/2022/06/PTvGB70l-1.jpg
https://static1.pt-content.com/images/pt/2022/06/cprCm20l-1.jpg
https://static1.pt-content.com/images/pt/2022/06/QOGHOoal-1.jpg
https://static1.pt-content.com/images/pt/2022/06/7dHU4dQl-1.jpg
https://static1.pt-content.com/images/pt/2022/06/2lfFBeOl-1.jpg
how many gallons did you use?
arcane73
06-26-2022, 09:05 PM
2 gallons of each. But I only did the floor, trunk divider, and roof. I have read that 2 gallons isn't enough if you want to do a whole car (doors, quarters, etc) but it was enough to cover the areas i did in two coats each.
