99socalfrc
06-15-2022, 03:16 PM
Exterior
Forgeline GA3 wheels
Michelin front tires
Nitto 555R2 Rear tires
Truck Lite LED headlights
Interior
Recaro Sportster GT seats
Planted seat brackets
TMI one piece headliner in suede
Morris Concepts 3 point seatbelts
TMI console
B&M Megashifter
Grant Alcantara wheel
Modified factory column with tilt
Autometer Ultralite II full LED gauges with dimming adjustment
Vintage Air
Drivetrain
Crate LS3 with 7000 miles modified with 229/236 .629 lift cam
Ported & Milled heads by West Coast Cylinder Heads
Ported & Rod Modded LS3 intake manifold
Fly by wire throttle body w/ OEM style ECM & TCM
Holley Stainless 1 7/8” headers coated by Jet Hot
3” exhaust with X-pipe, Magnaflow mufflers & over the axle exit
Holley motor mounts, oil pan & cross member
4L70e trans rebuild with beast sunshell, sonnax servos & shift kit
Yank PAS3800 torque converter
Tanks Inc fuel tank with notched corners
Walbro 400 fuel pump
All PTFE lined fuel lines
Griffin LS swap radiator with upgraded fans
Car was professionally tuned by Ryne Cuningham of Cunningham Motorsports/ BRC Raceworks
Suspension
Hotchkis 1.5” lowering leaf springs
Hotchkis 2” lowering coils
Hotchkis Fox shocks
Hotchkis subframe connectors welded in
Cal Tracs low profile traction bars
Quick Performance 9” rear end
TrueTrac positraction with 3.70 gear
4th Gen Fbody front discs
The Right Stuff rear discs with e-brake
Drilled & Slotted Rotors
Red powder coated Calipers
3rd Gen Camaro 14:1 steering box
I'm sure I forgot stuff, call or text 661-599-0792 Asking $65,000
200492
200495
20049620050320050220050120050020049920049820049720 0494200493200504
Interior
TMI console
B&M Megashifter
Vintage Air
Drivetrain
Suspension
Hotchkis Fox shocks
200492
200495
