View Full Version : Holley Terminator X or MPFI for 489 BB
FORDvsCHEVY
05-23-2022, 01:47 PM
So I am going to be ordering parts now for a winter install. Will have professionally done as i don’t really have the know how or time.
I have settled on Holley products and looking between two mentioned.
It’s putting out dyno’d 383 to rear wheels. Going to add a set of Brodix or AFR heads.
I have been looking at a torque storm SC but not sure of quality but may or may not add a power adder.
Pretty sure keep naturally aspirated, no more than 600ish HP but who knows.
I know the terminator will work but if is the MPFI better?
Performance?
Reliability (most important)?
Can Terminator ECU be upgraded to MPFI down road?
Again most likely NA with 600 HP will be most likely…. At least for next 5 years…
Did a lot of digging but most info I could find on here and the interwebs were 5-25 years old. Would like some current info
Thanks in advanced,
andrewb70
05-24-2022, 07:04 AM
Performance?
Thanks in advanced,
A multiport system is always better then throttle body injection. That said, I tune many throttle body injection systems.
There is no such thing as a "Terminator" ECU. There are Terminator kits in all variety, and they use the HP or Dominator ECUs. There are also many varieties of Terminator X ECU kits.
The hardware that is required to do a proper multi-port system is fairly substantial. You will ned an intake manifold with injector bungs, injectors, fuel rails, and a throttle body. You will also need a way to get both a crank and cam signal. There are various ways of doing that, with a dual synch distributor being the simplest way.
All of the current Holley ECUs, be it the HP, Dominator, Terminator X or Terminator X Max can do both throttle body injection as well as fully sequential multi-port injection.
FORDvsCHEVY
05-24-2022, 11:27 AM
Thanks. Helps a lot. Will dig into multi port to see if it’s feasible
FORDvsCHEVY
05-24-2022, 05:44 PM
Also do you know of anyone who makes a ram air intake for MPFI for a BBC chevy?
andrewb70
05-24-2022, 06:04 PM
Edelbrock has a nice big block manifold.
