Blown353
05-17-2022, 03:05 PM
All Sold 8-24
Working on my car again, which means changing plans yet again... up this time is more front suspension stuff. These were all on my 69 Chevelle but will work on a 64-72 A body.
Reason for selling: I'm modifying the frame and changing to coilover-only lower arms and modding the frame for extended length true coilovers up front with spherical bearing mounts on both ends, so I don't need all these parts meant for conventional style springs and shocks.
First up: a set of Global West CTA-42L lower control arms with Del-A-Lum bushings. The shock area has been opened up a bit to allow installing the larger diameter Varishocks and their adjuster knobs from the bottom of the arm so you don't have to disconnect the spindle and lower the arm every time to install or remove the shocks (Global West makes the new arms this way.) Still in good shape. Bushings and sway bar heim joints are still in great shape. Powdercoating has a few marks in it here and there, mostly on the bottom of the spring pocket where I put a floor jack or jackstands when working on the car.
IMPORTANT NOTE: These lower arms originally had B-body ball joints in them, as I bought these about 18 years ago when I did a B-body spindle swap, which was the "hot setup" at the time. Since there are much better options without the b-body spindle drawbacks now like tall spindles or stock spindles with tall ball joints, I have pressed out the b-body ball joints and have installed brand new QA1 modular ball joint housings (A B-body ball joint body is a larger OD than an A-body balljoint, so you can't simply switch to a stock-style A-body balljoint.) You will need to purchase the QA1 ball joint stud for your application (#9029-228 for a stock height a-body stud or #9029-211 for +0.5" tall a-body stud, plus #9034-107 dust boots) and then install the studs when you receive the arms, which is a 10 minute job with the QA1 #1891-106 ball joint service tools.
200100
200101
Next up: a set of Varishock QS2s. One has a slight surface scuff on the body where it contacted an off the shelf circle track threaded spring adjuster that located on the ID of the spring, and the threaded portion of the adjuster was too small to clear the shock body over the full travel range. I custom made spring spacers that instead registered on the OD of the spring that had a much larger ID than the threaded adjuster so the larger diameter varishocks wouldn't rub them anymore. No leaks, no shaft scratches, etc. They have about 5k miles on them. These shocks are slightly shorter than the "off the shelf" bolt in A-body shocks from Chassisworks, as my car was fairly low. The stock height A-body shocks from Alston were too compressed at my regular ride height and the shock body itself could contact the inside of the frame on full bump travel. Switching to a shorter shock fixed that. These are -4 length shocks with a 4.25" travel and 9.05" compressed length, 13.3" extended length, and an 10.75"-11.6" suggested ride height range. Update 8/24: I just purchased new bushings for the stem and lower eyelets from Alston as the old ones had cracks in the flange.
199839
Next up: several springs and spacers...
Previously I was running the car on 9.5" 750# tru-coils with the custom OD-registering spring spacers you can see in the pics. I ran them with 200# 11" single pigtail rear springs and the car drove and handled great-- pretty firm, but not teeth rattling.
199838
Also, I have a set of new in box Hotchkis big block 1" drop springs. These are 580#/in rate out of the box. I was going ditch the spring spacers and 9.5" circle track springs and switch to these Hotchkis springs and cut them as needed for final desired ride height (since the lower spring nest in the GW arms rotates, trimming the springs is an easy thing to do.) I figured they'd increase in rate to about 650#/in once trimmed to the final ride height I wanted.
199868
Asking $375 for the arms with the new QA1 ball joint housings installed
Asking $375 for the Varishocks
or $700 for everything above (arms, shocks, springs.)
I would prefer to sell this locally and not have to ship it, but I am willing to split the shipping costs with a buyer. I'm near Lodi, CA and am willing to deliver or meet up half way within reason.
Pic of car shown for ride height reference so you can see how it sat on the 750# tru coils with the GW lower arms along with ATS tall spindles, and also so you can get a good idea for the working height of the Varishocks. Front crossmember was about 5.25" off the ground.
199834
200100
200101
199839
199838
199868
199834
