View Full Version : Aftermarket subframe 67 camaro
JoseSS
04-27-2022, 11:44 PM
Is there an aftermarket subframe that will let me keep factory accesories on the stock ls3 location? 67 camaro
If i can save the 2300 for accessory relocation kit id rather spend it on a complete subframe kit as i noticed i can also save the extra 600 for motor mounts and trans swap kit.
Thats 3k towards a subframe kit. Plus the 2500 i was going to spend on ridetech stuff.
6k towards a complete kit doesnt sound bad and will keep my accessories down low. If they make something nice worth buying..199438
Z06vet
04-28-2022, 10:24 AM
What acc drive do you have?
dhutton
04-28-2022, 10:30 AM
5th Gen Camaro
Z06vet
04-28-2022, 10:48 AM
That will probably more difficult than the vette drive, which fits in just about everything. I feel like the speedtech would be a no, since its narrow. May be able to take some measurements between your AC compressor and Alt, and compare that to some of frame specs. I would think a call to the company who makes the frame should be able to help you somewhat.
JoseSS
04-28-2022, 10:49 AM
I have a 2012 camaro l99 doing an ls3 conversion and cam kit
JoseSS
04-28-2022, 10:53 AM
Ill just pick one of these 3. Any reason why i should spend the extra thousand for the holley kit?199447199448199449
Z06vet
04-28-2022, 12:23 PM
I have used both of the above acc drives in both stock frame, and DSE frames. I was happy with both. I had to get a smaller PS pump pulley for the vette pump when used in a stock frame and ridetech upper control arms. The stock pulley was right up next to the control arm with the holley clamshell mounts (which I highly recommend using)
JoseSS
04-28-2022, 08:00 PM
Im going to pull the trigger on the complete holley mid mount. Seems like il at least save research time lol
TANKMASTERJ
05-02-2022, 06:57 PM
Before doing Holley Mid Mount. Look seriously at the Wegner Automotive WAK033. It's like a mid mount. Compact. Beautifull machine work. Lots of belt wrap on PS and Water Pump. MADE IN USA. Like 2450.00
130fe
05-03-2022, 03:39 AM
I have the mid mount and love it. Another option is to get the Pace without AC accessory system and add the Holley high mount AC. Works good and matches with the factory bracket. Only thing you would need is the corvette water pump and balancer.
https://paceperformance.com/i-6485405-19421445-cpp-accessory-drive-system-without-a-c-fits-ls2-ls3-ls7-engines.html
https://www.holley.com/products/ls_power/ls_and_lt_accessory_drives/gm_ls_accessory_drives/high_mount/air_conditioning_drive_kits/parts/20-141?utm_term=&utm_campaign=Google+Shopping+-+Holley+-+Brand&utm_source=google&utm_medium=cpc&hsa_acc=7848552874&hsa_cam=931687581&hsa_grp=105548458508&hsa_ad=421539310074&hsa_src=g&hsa_tgt=aud-561455909642:pla-1213978004604&hsa_kw=&hsa_mt=&hsa_net=adwords&hsa_ver=3&gclid=EAIaIQobChMI2vDxnJ_D9wIVKHFvBB0BggPpEAQYBCAB EgLD2PD_BwE
