View Full Version : 5th Gen Camaro brembo brakes with AFX brackets
GTOtzel
04-26-2022, 10:24 AM
Front brakes from my project. I have the 2010-2015 Camaro Brembo calipers rebuilt with all new parts and coated Red.
Calipers are loaded with Power Stop pads.
14" Drilled and Slotted rotors with the stock 5x120 bolt holes and also drilled 5x4.75 holes for 1/2" studs.
Setup includes Braided Stainless lines.
Also available are brackets that use Wilwood 270-7037 hubs. Currently mounted on Ridetech spindles.
Will work on stock GM spindles. Will fit behind an 18" wheel.
All parts are brand new and have 0 miles on them. Decided to go a different direction.
$700 for Loaded calipers, Rotor and Braided lines.
$800 with caliper brackets.
199295199296199293Located in Harrisburg, PA
GTOtzel
05-03-2022, 02:59 AM
bump
