Results 1 to 3 of 3
04-25-2022 #1
Solid body bushing installation at core support
Hey guys,
maybe someone here has some insight on this. I had the subframe out of my 68 Firebird, and installed Global West interlocking body mounts when I went back together. We had the core support out, and I just put it back in yesterday. When installing the core support, we installed the male portion of the body mount through the top of the core support, with the female section sitting on the frame. The instructions tell you to do the opposite (male section sitting on frame).
Is there a problem with how I have it? The height of the two bushing pieces looks the same, and they’re still interlocking as they would be if flipped. It’s hard to measure them when installed, so I suppose there could be some height difference, but my core support fit back in pretty well. Thoughts?
Andy
1967 Camaro RS
Magnacharged LS1/T56
543 rwhp, 516 rwtq
Sold
1968 Firebird
LS427/570 and T56 Magnum
04-25-2022 #2I guess I’ll answer my own question in case anyone else runs into this: It doesn’t matter which direction the core support bushings go; at least on a first Gen with the GW bushings. The height of each bushing shell is the same height, and the orientation doesn’t matter. This is per Doug at Global West.
Andy
1967 Camaro RS
543 rwhp, 516 rwtq
Sold
1968 Firebird
04-29-2022 #3
