View Full Version : Cold Air Intake options for LSA Swap 1st Gen
Senek67RS
04-18-2022, 12:46 PM
I am hoping that someone has already found an option for folks that swapping LSAs into their 1st gen Camaro. I had one from Frank on my LS3, but because the angle on the TB now, that no longer is working.
joeko23
04-20-2022, 12:50 PM
Rotofab for 5th gen Camaro fits. You’ll have to trim the big Aluminum L thing (don’t know what it’s called) but it will contact the inner fender. You’ll have to grind it to fit the contour of the inner fender. That’s what I used for my swap. You can find them pretty cheap on Camaro5 forum.
Senek67RS
04-20-2022, 05:17 PM
Thank you, but I am looking for something similar to what Frank does, but for an LSA. I like that closeout panel and the air filter being tucked away and hidden. Also, running out of room in the engine bay lol
joeko23
04-20-2022, 07:02 PM
Can’t help you then lol. I don’t think there’s anything out there like that unless it’s custom made. Frank doesn’t make them for LSA, but maybe for LT4/5? The angle of the throttle body is similar to the LSA I think.
TheCrucible
04-21-2022, 06:38 AM
Same problem here, I just swapped LT4 and Magnuson in my Nova, probably going to have to build from scratch. Let me know if you find anything that works? Thanks!
Senek67RS
04-21-2022, 07:14 AM
That is what I am thinking as well, but will let you know if I fins anything.
ryeguy2006a
04-21-2022, 07:31 AM
Did you contact him to see if he could modify it?
srode
04-23-2022, 12:13 AM
Who's this Frank that makes the intakes?
joeko23
04-23-2022, 05:17 AM
Here you go:
https://www.pro-touring.com/threads/130901-1969-68-67-camaro-Ls-swap-custom-cold-air-intakes?highlight=Ls+intake
icemanrd19
04-23-2022, 06:19 AM
Airaid I build it. Simple, lowers iat, and cheap 199151
srode
04-23-2022, 01:33 PM
Nice work! Probably close to the angles I need for mine.
