View Full Version : Hydramat.. Is it worth the $
Just 1 More
04-07-2022, 09:17 AM
I have the Holley tank kit (Tanks Inc) 19-401 which has the 400 lph fuel pump and says "Internal tank baffling includes a large 4.3 liter internal fuel tray to prevent fuel pump starvation"
I asked Holley about a Hydramat for this tank and they said the 16-124 ($158.94) 3" X 8" HYDRAMAT®, RECTANGLE CENTER OUTLET would be a good mat for this tank. Would it be worth adding the Hydramat?
Opinions? Facts? testimonials?
TheBandit
04-07-2022, 01:52 PM
3" x 8" isn't all that big. I think my Walbro 255 came with a sock about 3" x 6". What comes on the pump?
dhutton
04-07-2022, 02:46 PM
A Hydramat is not a sock. Completely different, it is a fuel starvation prevention device.
Don
TheBandit
04-07-2022, 03:09 PM
By "sock" i'm referring to the fuel pump inlet strainer like this one typical on a Walbro pump:
198839
Here is a photo of a 3x8 hydramat from Holley's website - similar size and material, maybe not exactly the same, but basically a filter-type porous material
198838
I think either of these will draw fuel from any area they cover as long as they are wet, and therefore act as a fuel starvation prevention device based on the surface tension of the fuel in any given micro-passage. I'd be willing to bet if a pump strainer is wet, you could dip just a corner into fuel and draw fuel just fine.
Am I wrong? I'm fine with being wrong.
slammed68
04-10-2022, 04:56 PM
198839
198838
The Hyrdamat alone costs more than a 255lph walbro. Infact you could buy 2 walbro 255s for the cost of the cheapest hydramat sold. so no...its not the same as the sock that comes included with your pump.
Hotwire
04-11-2022, 03:52 AM
You don't have anything to worry about. I have a tanks inc tank in my a-body and completely sucked it dry with no problem. Just follow the directions when installing the pump and you'll be fine.
