View Full Version : 1st gen convertible corner weights.
Johnny Blaze
01-05-2006, 10:42 AM
Wondering about the weights that are placed in the coners of the first gen converts.
Can these be removed, or should they? What do they really do, if anything.
derekf
01-05-2006, 10:45 AM
They should not be removed. They're there to help with the vibrations that happen in the convertible F-bodies.
From http://www.chevy-camaro.com/faq/chevy-camaro-convertible-cocktail-shakers.shtm
On the corners of convertibles there are what's called "cocktail shakers" or vibration dampeners which were originally installed on every first gen convertible Camaro to help prevent vibrations. They were installed due to a very flexible body in the convertible models because of the lack of the roof structure. Some reinforcement was added to the convertible rockers and floors but it wasn't enough to prevent all vibration problems. The cocktail shakers are large cans with a suspended mass on a spring in a viscous fluid that are mounted on the corners - 4 in all. They were tuned to a resonant frequency of the convertible that caused the vibration problems. When the body was subjected to loading that would otherwise tend to make it oscillate, much of the energy was instead absorbed by the motion of the masses in the cocktail shakers - which reduced the vibration in the convertible body. The cocktail shakers weight about 25 pounds each.
It certainly would be possible to add a large amount of structural stiffness (subframe connectors won't be anywhere near enough) to the mid-section of the body to reduce or eliminate the vibration to the point of being able to remove the cocktail shakers. However that possibility would be very remote without a complete understanding of the Camaros stress and flex points. Another option would be to design and build your own vibration dampener. That, however, would require knowledge of the structural frequencies of the Camaro convertible body not to mention knowledge of how to tune the damper you are creating. The cocktail shakers are filled with automatic transmission fluid or ATF. The fluid is not subjected to friction, high heat or contamination as is the case with other fluid applications in the vehicle so it should not "wear out". The springs would be the only thing that could change or break, that would keep them from working properly. We have never found a "bad" one, if it still has fluid in it, only cars missing them which have the common 'cowl shake' much worse than normal. If your convertible Camaro has all four cocktail shakers and you still have bad vibration problems be sure to check that your tires are balanced properly and also new OEM body bushings can help reduce some of the vibration transfer. Be sure to check your springs and shocks as well. You should also try adding subframe connectors to help with flex and vibrations
Johnny Blaze
01-05-2006, 11:05 AM
Interesting. So, subframe connectors alone whould not do it.
Man, that 100 pounds I'd love to lose!
Anyone who has removed them, care to share their expereinces?
BonzoHansen
01-05-2006, 07:17 PM
Look here http://www.camaros.net/forums/forumdisplay.php?f=31
