View Full Version : 6 piston brakes off my chevelle front and rear
classiccarcustoms
03-12-2022, 11:00 AM
I have a front and rear set of brakes off my 1970 Chevelle convertible that I will be selling.
Factory ZL1, CTSV 6 piston front and rear brakes, KORE 3 brackets included to fit stock camaro, chevelle spindles and 10/12 bolt rear end.
I am going to be selling the car so I am removing the front rear brakes and putting smaller ones on so that I can put smaller wheels and tires on the Chevelle before I sell the car.
Everything is included front two piece rotors, front 6 piston calipers, brake pads, Kore3 Bracket to go to a stock spindle. Rear rotors, rear calipers and bracket as well to go on a 12 or 10 Bolt.
Banjo bolts and steel braided brake lines.
$1,800.
Location st George UT
198064198065198066198067
70Uglybird
03-12-2022, 01:38 PM
Does this include parking brake setup?
lbsurfer11
03-12-2022, 05:38 PM
Can you tell me the diameter of the rotors please? thanks
Tpichevy
03-12-2022, 09:39 PM
Did you run a spacer up front to keep the wheels from hitting the caliper?
classiccarcustoms
03-13-2022, 06:23 AM
No parking brake
classiccarcustoms
03-13-2022, 06:26 AM
The the wheels I was running I did have to run a 5/8 bolt on spacer. I put my Forgelines off my 69 Camaro on there and I was able to remove spacer. All depends on your wheel and offset.
I am going to sell the car and was going to put stock 17" SS looking wheels on her. Those won't clear the front caliper at all.
classiccarcustoms
03-13-2022, 09:59 AM
14.25” front and rear.
Corinthian
03-15-2022, 05:30 AM
Are you running 19's to clear this or do 18's fit?
classiccarcustoms
03-15-2022, 01:49 PM
I was running 20’s.
They cleared.
Not sure if 18”
classiccarcustoms
04-27-2022, 08:14 AM
Bump
Will also include power brake booster, Wilwood billet master cylinder.
samvera31
04-27-2022, 07:45 PM
Can the brakes clear 18" wheels?
classiccarcustoms
04-28-2022, 05:51 AM
Not sure. I had 20” on the car and they cleared.
classiccarcustoms
05-27-2022, 12:58 PM
Memorial Day bump.
classiccarcustoms
11-23-2022, 05:13 PM
Sold
