Pedigry
03-09-2022, 07:43 AM
Hey guys,
I have a question. I have reviewed every video and forum that I could on this subject and its still not quite clear to me. I have a 70 mustang with a 4 link and coilovers. The car is pretty low. It has a C6 in it with a gear vendors overdrive setup. It's snugged up into the trans tunnel as far as it can go. I am chasing a drivetrain vibration and need some help with the pinion angle.
When I got the car, the measurements were:
engine/trans down 3.5* * (engine slopes down toward rear end)
driveshaft down 1.5* (DS slopes down toward rear end, same as the motor)
Pinion 0* (level with the ground)
After reading a ton on the subject, I felt like I should try an get the pinion to match the engine (apposing angles), so I raised the pinion to 2.8* up (leaving a little for rotation). Now the DS is at .7* down. The issue I am having is that the working angle between the DS and the pinion is now a positive pinion angle. In other words, it doesn't form a "V" like it should, but an upside down "V".
So currently the car is:
Engine/trans down 3.5*
driveshaft down .7*
Pinion 2.8* up (pinion CV is 2.8* point up)
I have read that is a bad thing, as the rear end rotates up under acceleration, that working angle gets worse and is potentially binding. Everything I have read says you never want a positive pinion angle. Most of what I have read states you should just set the pinion 2* downward angle (pinion 2* down toward the ground) and call it a day.
With the current setup I have, I can't raise the tranny anymore than it is without hacking the tunnel, which I won't do. So the only other way to change pinion angle is raise the car up a bit, which I don't really want to do, or simply keep adjusting the pinion angle to try and relieve the vibration (which currently is when the car is slightly off power or on deceleration).
With a 3.5* downslope on the motor and the car being as low as it is, there is no possible way to have the motor and the pinion to be equal and apposing angles. I'm trying to avoid a positive pinion angle. Not sure where to set this thing.
Thanks.
driveshaft down .7*
Thanks.
