shan
01-31-2022, 10:54 PM
Hi Guys,
I have been looking for a specific answer to my question, and have trawled through pages and sites - had no luck.
I am from australia, and we had variations of the LS engines in many of our local cars. In my case, I have an L98, which is a variant of the gen4 LS motor.
The harmonic balancer arrangement is confusing as USA info and images do not exactly match ours, but from measurements taken, I appear to have the corvette/cts-v style setup.
This LS will be going into my 1968 Camaro, with standard chassis.
I am using the complete holley swap system (headers/engine mounts/cross member). Only just bought the gear from summit, so is latest iteration.
I do NOT want to notch the crossmember (lots of paperwork in australia to get mod's like that approved).
I have classic auto air, which uses the Sanden 508/507 style AC compressor currently.
FYI - I’ll be going high-mount for the alternator…..come to terms with the fact it can’t be low mounted without notching the crossmember. I would still like to hide the AC if possible.
I found low-mount AC brackets from various vendors, but when I read the fine print, many say the “may not” work with Holley v1.0 and v2.0 engine mounts.
Then other posts have mentioned issues with low-mount AC clearance depending on your balancer.
Then of course, is which compressor you are running. Seems like the mini variant of the sanden unit might be necessary?
Leaves me a little uncertain….
My questions:
Has anyone used the Holley engine mounts, AND combined it with a low-mount AC bracket, to successfully clear the cross member on the 1st gen Camaro (standard chassis) with the Corvette style balancer?
If so, which brackets were used and which compressor was this achieved with?
Shan
My questions:
Shan
