Results 1 to 11 of 11
Thread: Hydroboost setup
01-04-2006 #1
Hydroboost setup
I never thought about actually putting one in because I thought they cost 6-700 dollars. They do show up on ebay from time to time like this one.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
So now I'm wondering what mods or Fab work needs to be done to mount this to the firewall and connect it to the break pedal. The hoses I don't think would be a problem for me.
01-04-2006 #2I did just what you are doing, only I bought a hydroboost unit that came with the master on it. You can bolt it dorectly to the firewall using the plate that it comes on. You will have to spin off the nut that holds the unit to the plate. Then you need to take out those studs that are in there and maybe shorten the plate. I did.
Then, I patterned the holes from my pedal assembly and drilled them on the plate. Bolted it up and walla!
What you will need to do, depending on your car, is cut off the loop on the actuator rod and thread it. I threaded most of the rod and put my clevis right on there and it was good to go.
I had all my lines made and used braided stainless steel. You will figure out which one goes to pump and which one goes to resovior. If the steering wheel pulls when you brake, the lines need to be reversed.
We have done these conversions to about 5 of my friend's vehicles lately. One did it, then me and now we are all doing it.
IF you decide on enlarging your disc brakes, it is a must have. It is a lot lower profile than the booster and if you have tall valve covers, they do not hit the unit.
For some reason, the unit will most likely need to be flipped upside down to work properly. I was told because of pressure, but he could have been wrong. Either way, depending on your conversion, it may not work right side up and if it doesn't, just flip it and it will be good to go.
I think that I have @ 300 in the conversion. $150 were for lines and fittings.
Hope that this helps.Semper Fi
01-04-2006 #3
- Join Date
- Oct 2004
- Location
- Oswego il
- Posts
- 938
