View Full Version : Ford 9” center section bad?
1985olds
01-17-2022, 04:15 PM
So, over the winter I did a lot of work to my 85 cutlass. New ls3, new McLeod rst, new quick performance 9”, new poly body mounts, new 2” lowering springs on all corners, new bilsteins on all corners, new frame braces, new front lca’s, new driveshaft. I have been chasing a shake in the rear of the car now since I got it back together. So far I have verified pinion angles, balanced the back wheels, new driveshaft, verified the wheel base, adjusted my sway bar to not hit the rear end housing, moved my tailpipes to not hit the rear and verified not contact to the frame or anywhere on the axle housing. I still have a shake in the car. At 60 mph I can start to hear a groaning and by 75 it’s shaking. If I left off the gas at 75 mph it gets worse. The one thing that is not brand new and was bought used was the ford 9” center section. Could that be the issue? Thank you.
130fe
01-18-2022, 04:23 AM
What are you driveline angles? Does it vibrate at lower speeds?
1985olds
01-18-2022, 07:44 AM
Cannot recall the angles off the top of my head, they are written down at my shop. I used the TREMEC driveline app to verify them though. No low speed vibrations that I can tell
