View Full Version : best option for a chevelle frame
aidanfancystang
01-01-2022, 10:25 AM
so i picked up a new project, its a 64 beaumont SD so pretty much a chevelle, my question is can a stock frame be made to handle as well as an aftermarket frame for a little less investment or is it best to go with a full frame replacement? i want to build a 500-600hp 5 spd car that will handle well, and brake well. Road coarse and slalom type driving.
just looking at where the best place to spend the money, I have had a bad habit of just buying parts randomly and then changing direction later and having wasted money on parts i dont use.
just looking for the best advice, thanks.
csouth
01-01-2022, 10:50 AM
I would start with either a Speedtech or Summit Racing chassis bracing kit and the ABC performance frame notch kit. After that choose a nice bolt on system, front and rear from the same vendor. Aftermarket chassis are very nice, but they usually start a trickle down effect of other more expensive parts like headers, tunnel work and fuel tanks. Lots of guys having fun with their cars not using aftermarket chassis.
MonzaRacer
01-01-2022, 12:20 PM
Go check out videos on Ridetechs 66 Chevelle
67-LS1
01-01-2022, 01:56 PM
Boxing the frame and adding braces will make a HUGE difference to an A body frame. Will it be a Morrison frame? Nope. But like csouth said with a beefed stock frame and a full suspension makeover it will handle amazingly compared to stock.
pitts64
01-04-2022, 02:48 PM
The parts I recommended is for a street driver and will not be the best for road course racing.
I think keeping the stock frame and boxing it or use the A.O.Smith # 1942 frame. It only came on the 68 to 72 el Camino or 69 to 72 Pontiac Grand Prix Model J. I would also need a little extra bracing and the upper control arm brackets moved back and squared with the frame.
195275195267195274195266
aidanfancystang
01-04-2022, 08:36 PM
so if i use the stock frame what are my best options for control arms , and frame strengthening kits?
raustinss
01-05-2022, 10:23 AM
Hpi customs is the maker of the summit frame brace kit , them or speedtech are my suggestions. Speedtech also makes lots of suspension parts..Eg. AFX spindle which will make massive differences to handling and steering
67-LS1
01-05-2022, 12:02 PM
Is it me? Am I losing it?
I thought there was a post on this thread yesterday about relocating the front upper control arms rearward 2”. it’s not here anymore but it’s referenced by pitts64 in his post. Does anyone else remember this?
I’d certainly like to learn more about this mod.
andrewb70
01-05-2022, 12:03 PM
That's like asking "what pizza is the best?"
There are a dozen companies that have been around for decades that offer great products. You should explore all of those options and decide what's best for you.
I am installing Ridetech suspension of my 70 GTO. I also had a buddy with a 70 GTO that used the Hellwig frame boxing kit, and it was very well designed, although it is more expensive than other options.
Chocolate Apocalypse
01-05-2022, 12:54 PM
Yep, I remember seeing it. Something similar to the Gulstrand mod though 2" sounds a bit much.
67-LS1
01-05-2022, 01:06 PM
That’s what I thought. 2” was A LOT.
I wonder what happened to the post?
aidanfancystang
01-05-2022, 07:39 PM
I did see that one as well and it had me wanting to find out more on that. but yes 2" seems quite extreme.
67-LS1
01-06-2022, 12:22 PM
I did some reading about the Guldstrand mod and it appears to be a Camaro mod that moves the upper control arm frame holes down 1” and .25” rearwards. There are debates about whether this is a viable option for Chevelles.
And it seems to have been kind of obsoleted by the advent of tall spindles or tall ball joints.
Instead of closing up the spread between the inner mounts for the upper and lower control arms, the tall spindle or tall ball joints spread out the ball joint ends of the arms.
Sorry this got off track…
UMI Tech
01-07-2022, 06:49 AM
The UMI LeMans went through the tri oval at Daytona at 165 on a stock frame and with our #cornermax kit.
It has a boxed frame and a moderate cage.
https://youtu.be/mr_6uMG_0xA
The rear suspension is the factory converging 4-link with UMI arms and sway bar.
Hotwire
01-14-2022, 04:31 AM
I was behind the LeMans @ the Summit Autorama in 2019, that car was flat as a pancake going through the autocross.
GEARBOXGARAGE
01-14-2022, 05:08 PM
While the aftermarket chassis choices are nice, the price gets steep really quick when you start adding on the ancillary items. We put an Art Morrison under a 64, and while the quality was very nice and the car rides like a Cadillac, the full delivery price after options was $25K. That was 5 years ago and prices are up a bit since then. A SpeedTech ExtReme chassis is another good one if you are looking for more of a track day setup, but again you are going to be north of $20K buy the time you option it out and pay for freight. We are putting the Speedtech stuff under a 70 Camaro and it's built like a tank. But don't overlook utilizing your factory chassis. GM really wasn't too far off the mark when they designed the mounting points for the suspension. It's the extremely short steering knuckles and poor factory alignment specs that kill the platform instantly. Tony at ABC Performance is an extremely talented guy with a lot of engineering experience that carries over from his days at the GM proving grounds plus he has a huge pot to pull from in his network. There is a reason his 2 Ton Chevelle can keep up with cars that are lighter and more technically advanced. At the 2021 Motorstate Challenge his car came in First (Co-Driver Mathew Braun), Third (With Tony at the wheel) and pulled the fastest Track Sprint Time (Mathew again) in the Manufacturers Vintage Class. Same goes for the Northeast Muscle Car Challenge, Mathew took first place in road race, autocross and Grand Champion. Granted he is an extremely fast talented driver (I have ridden with both of them and Mathew is on a whole other level!!) but having a car that can hold up to that and hook the way it does is simply amazing and says a lot about Tony's products and the engineering he puts into them. Regardless of which option you go with, unless your driving level is at the point of pushing the car to its absolute limit, you probably won't see much of a difference between the options. I used to think that the aftermarket chassis is the most competitive option, but after riding with Tony and Mathew and getting to know Tony and where his background is, I would give ABC a strong consideration.
195545195546195547
raustinss
01-15-2022, 11:49 AM
Tony definitely knows his stuff and I also have had a ride in his 70 ... wow its awesome
chevelletiger
01-22-2022, 02:13 PM
I have also spoke with Tony on the stock chassis,and spindles.
I currently have the stock short spindle with tall ball joints,with speedtech upper and lowers.
I might go afx spindle but tony. Said the stock spindle is pretty strong,he runs the dse tall spindle with tobins kore3 hubs.
Which I might go with a custom hub from tobin with the larger set3 .750 I'd outter bearing.
chevelletiger
01-22-2022, 02:19 PM
195545195546195547
Tell tony,and t.j. that they need to be more active on the forum and social media!
