View Full Version : What EFI unit are you running?
TZmtrsprt
11-29-2021, 06:43 PM
Hi all. I bought a name Mfg EFI kit in Feb this year which included the EFI unit, distributor, coil and spark box, all included. When it runs, it runs great. I really like the EFI/timing part of it. But I have had BIG problems with the unit. You would drive it, then after 200- 500 miles the unit would just quit. Mfg claims bad distributor first time, a bad ECU now. New "updated" ECU from Mfg, same problem. Kinda done with Mfg. What EFI units are you running out there? I have A 1968 Camaro with a mild 350HP 350 SBC. How do you like them? What is the good and bad about your EFIs? Like I said, when the Mfg unit ran, it ran great! I really liked the way the distributor and EFI/ECU worked together. Thanks for your help.
Just 1 More
11-30-2021, 06:01 AM
Holley Stealth Terminator X with Hyperspark Dist, Hyperspark Coil, Hyperspark box
btmatt
11-30-2021, 06:33 AM
man that is unfortunate. currently using Holley Terminator X, Sniper with Hyperspark, Megasquirt Gold Box, and in build phase of a turbo car with ProEFI 128.
So far so good with all, but you have to be spot on with your wiring
TZmtrsprt
11-30-2021, 11:25 AM
Thanks for your input. How long have you used it? How do you like it and have you had any problems?
Just 1 More
11-30-2021, 11:34 AM
No issues so far. I used AndrewB for tuning and that was the biggest help
Camaro68+69
I'm running an FiTech unit in my 68 Camaro Convertible with a 396 motor, I think it works great, turn the key, fuel pump kicks on, 4 seconds later car starts right up, no problem, even after sitting for months...
elwaupo
04-26-2024, 06:22 AM
I’m running a Sniper, nothing but problems
BK2LIFE
04-26-2024, 03:54 PM
i tell my customers under 600rwhp use all stock GM computers.
Above that hp level switch over to the holley terminator stuff to run all the gizmos and gadgets with it.
Alponcho
04-27-2024, 09:31 AM
Sniper on a fresh 535ci Pontiac, no problems after 1k miles or so.
