View Full Version : GM bellhousing 3899621 and Billet adapter plate TRG 00901
ztk123
11-15-2021, 05:14 PM
GM 3899621 Bellhousing and Billet Adapter plate a TRG 00901. Both have been used for mock up, I was intending to use both with with an aftermarket Tremec T56. I have since purchased a T56 magnum and sold the other T56. Willing to separate $225 OBO
8mywal8
11-24-2021, 08:43 AM
if I am reading correct this is not the right plate for a T56 Magnum?
ztk123
11-24-2021, 06:24 PM
Correct, it bolted up fine to an aftermarket Tremec t56. The T56 magnum I bought bolts up to it but doesn’t completely tighten down due to have a portion of the case that prevents it (round spot that protrudes) from doing so. I could mill a small spot on the plate but thought I’d list it for sell.
Donovan
11-27-2021, 07:12 PM
I read through the add, apologies if I missed it. How much for the adapter without the bellhousing? Thank you
ztk123
11-28-2021, 07:00 AM
Thanks for the interest but I sold the adapter plate this morning to a member passing through Louisville. I still have the bellhousing.
Donovan
11-28-2021, 01:04 PM
glad you found a buyer!
KAN KAN Speedshop
12-07-2021, 12:13 AM
PM Sent
ztk123
01-07-2022, 03:09 PM
Bellhousing still available $125.
