View Full Version : C5 front caliper hose routing on 67 Camaro
gui67
11-11-2021, 03:16 AM
Hi,
I don't really the way I installed the hoses on my 67 Camaro to the C5 front calipers. (Kore3 kit)
As the Caliper side is a Banjo, there is no really a defined direction.
Currently the hose go down and make a big loop to the rigid lines. I also tried more a "S" shape, but it was a bit too rigid to my taste and making it flex a lot.
How did you install yours? Do you maybe have pictures? are they not too much flexing during turns?
Thanks in advance for your answers
Guillaume
68sixspeed
11-15-2021, 11:41 AM
"Big U" is normally correct, double check it with the wheels turned locked to lock as well as allowing for suspension travel to be safe. Most of the stainless braided hoses hold their shape pretty good.
Rick Dorion
11-16-2021, 03:07 AM
Ditto what Dan said. I have Kore3 C5 setup on my Bel Air as described.
gui67
11-19-2021, 08:11 AM
Thank you, I will do i like you said, a big U, and check that nothing is rubbing during the turns
