    Results 1 to 13 of 13
      Oct 2017
      St. Louis
      Vintage Wheel Works V40 or V45 17x8 or 17x9
      Anyone running these wheels? any pics if so? I really like these and would like to buy a set so want to see real pics of them on cars.
      Jul 2008
      Dallas, TX
      I run some of the original v45's in 17x9.5 and 17x11 (center section is cast and welded to rolled hoop). My understanding they no longer do custom wheels and you only can get them in a few sizes that are all cast from Coker. On the Coker website they only offer one 17" wheel: 17x8, 5x4.75, 4.75" BS. Can't speak to the quality of them.
      '69 Chevelle - LQ4/T56
      '71 GMC SWB Fleetside - LM7/AR5
      V45s on my 64 chevelle
      For some reason cannot get pic to attach
      Hopefully it attached this time
      Oct 2017
      St. Louis
      Looks good on the Chevelle!
      Mar 2011
      FYI - Vintage wheel works was bought out by Coker tyres. They only make the ONE piece wheel last I checked. The chevelle in pic is wearing the TWO piece wheels, and the 2-peice had more customisation available (BS, width etc). I was saving $$$ to buy the 2-piece V45 in 17" for my 68 camaro and was gutted to find out Coker had scaled back the options after buying the company. I was lucky enough to find someone selling a brand new set in the exact dimensions I wanted (total fluke), but yeah - just be aware the options on these wheels (last I checked with coker anyway) was that they were making the one-piece cast units only. I also advised Coker they were using pictures of the 2 peice wheels in their advertising material (which was misleading given they do not sell them anymore) and they were still using those images last I checked. Would post a pic, but I do not have them fitted to my car yet.....sorry!
      Aug 2005
      Hamilton, NJ
      Scott from NJ.
      Vent Windows Forever! ...
      Jun 2001
      Newbury Park, CA
      V45 with 275/40/17 square.
      Scott is spot on about VWW. The ET's are the closest I've found and are the likely candidate if/when rim replacement is needed.
      Oct 2017
      St. Louis
      I have come to find that Coker did cut off all options on the wheel and only offer specific sizes. In the mean time I have also run across a couple other similar styles that come in different sizes.
      https://voxxwheel.com/wheel/6994/bg-...?finishID=2115
      https://www.uswheel.com/wheel/7679/u...?finishID=2572
      Aug 2005
      Hamilton, NJ
      I've been searching for how your car was setup. I even searched the wayback machine for your old geocities page.
      What wheel sizing did you use to achieve 275s all around? That was stock frame, no tubs back then as well?
      Trying to get my 67 setup.
      Quote Originally Posted by CarlC View Post
      Scott from NJ.
      Jun 2001
      Newbury Park, CA
      Quote Originally Posted by BonzoHansen View Post
      17 x 9.5 x 5.5bs. 275/40/17 square. The newest 18 x 9.5 x 5.75 allow a bit of adjustment with 1/8 - 1/4" spacers. It's tight.
      -3 - -2.5* camber, 5.5 caster, 1/16" toe in. Buttonhead bolts around the outer wheelwell. It rubs the subframe/reduced turning radius but it's fine for normal driving, autocross, road course, etc.
      Aug 2005
      Hamilton, NJ
      Thanks Carl. I'd have bet anything they were 17x9s. The 18x9.5s on my 2nd gen fall right into your backspace size spread, I didn't think that would be the case. I just got handed a free set of 17x9 zr1/4th gen wheels I might use, I just need adapters.
      That's a stock frame and no tubs?
      Scott from NJ.
