View Full Version : Borgeson joints
65 drop top
10-13-2021, 10:40 PM
I need to order some Borgeson joints to get the steering set up on my current project. Do you guys recommend the vibration reducer joint or can I just use the standard type joints? I believe the rack is mounted via polyurethane bushings, DSE rack on AME chassis. Thanks.
PS, I do have the vibration reducing joint on a different car in place of the rag joint, but that’s all I’ve ever had on it so I don’t know if it really does much.
dhutton
10-14-2021, 03:48 AM
In my experience it does make a difference.
Don
dontlifttoshift
10-14-2021, 04:37 AM
Yeah, they help. I don't build with them but I do swap them in as needed. Not every car needs them but some steering linkages get a harmonic in them and the wheel will start shaking for no apparent reason and the vibration damping U joint cures that.
One other thing, I have put together some very quiet cars, and without the vibration reducer u joint you can hear the fluid flowing through rack when turning as the sound transfers through the linkage and column.
65 drop top
10-14-2021, 09:34 AM
Thanks guys. I’ll get the vibration reducer joint.
Jeff_G
10-14-2021, 11:31 AM
The vibration reducer is always a good idea, it gets rid of hand numbing road vibrations and will also work to mitigate any hydraulic noise from passing up through to the steering wheel.
dontlifttoshift
10-14-2021, 01:38 PM
Hydraulic noise is a far more eloquent way to say what I was trying to describe.
79T/Aman
10-21-2021, 01:39 PM
if the intermediate shaft is non telescopic it is best to use the damper, especially with an aftermarket frame and R&P where you also may get bind under load.
