woody.rbsn
09-27-2021, 01:45 PM
1964 Jeep Gladiator J300 on ASA Pro Truck Chassis. Registered, insured, and pink slip in my name. 5.3L Aluminum LS.
Asking $15,000. Open to trades. Build tread in the Pro-Touring Truck Section.
-1964 Jeep J300 Cab; clean CA title, smog exempt
-ASA Pro Truck, Port City Chassis
-Winters Quick Change Rear End; helical gears currently installed, extra straight cut sets provided
-Howe Racing Hubs
-AFCO Suspension Components
-Tilton Dual Master Brake Cylinders; brake pedal bias adjuster
-RCI 16 Gallon Fuel Cell; 91 Octane
-Basset Racing Wheels; 1 set of mounted Pirelli slicks. 1 set mounted Hankook DOT tires.
-Corbeau Racing Seat
-Simpson 5-point Harness
-AutoMeter Gauges
-Painless Performance Blinker/Brake/Emergencies Kit
-4L80E Transmission; manual valve body (listing as manual although technically automatic), sidewinder gated shifter, Derale transmission cooler with shroud/fan
-2004 5.3L LS LM4; from 2005 Buick Rainier, Aluminum Block, ARP LS2 Head Bolts, Summit Racing Stage 2 Cam (Pro LS Vortec Truck), PAC Racing Springs 1200 Series, 42lb Delphi Injectors, Earl's Fuel Pressure Regulator, Walbro Fuel Pump.
-C&R Racing Radiator 804-31191 / 2 Row Crossflow, 160 Degree Thermostat
192266192267192268192269
-Howe Racing Hubs
-AutoMeter Gauges
