View Full Version : 600 steering box where to buy
69cutlassrkt
09-21-2021, 04:37 AM
Anyone know where I can get a 600 box for my 69 cutlass?
I thought I had one from ridetech, but it's an 800 series. They should list it as an 800 box. I'll be returning it.
protour_chevelle
09-21-2021, 05:03 AM
Sweet manufacturing. I just installed one.
dontlifttoshift
09-21-2021, 07:46 AM
What did you buy from RideTech and why do you think it is an 800 series?
If you got the Borgeson box from RideTech, I can tell you that I had it in my car after a Delphi 600 box and then replaced the Borgeson with the same Delphi 600 box and there was absolutely zero difference in the way the car drove or felt.
69cutlassrkt
09-21-2021, 06:01 PM
Because the part #800130 on the paper that came in the box. And it looks exactly the same as my old box. Unless I'm mistaken and the 600 box is the same size as the 800.
https://www.summitracing.com/parts/brg-800130
This is the one I bought.
https://www.ridetech.com/product/borgeson-12-7-1-600-series-steering-box/
79T/Aman
09-21-2021, 06:08 PM
Pro-Touring F-Body got em on the shelf
69cutlassrkt
09-21-2021, 06:28 PM
Thanks, I will call them.
Pro tour chevelle. Them sweet units are a little pricey for me. Thanks though
dontlifttoshift
09-22-2021, 04:44 AM
Because the part number starts with 800? Every Borgeson steering box starts with 800 and none of them are 800 series steering boxes. Maybe your box was already upgraded, I can't tell, I can't see it from here.
Install the steering box you bought from RideTech. Like I said, the 800130 is virtually identical to the Delphi 600 box and if someone swapped them in your car you would never know.
79T/Aman
09-22-2021, 04:51 AM
what is "pricey" a 600 series box is at minimum $800, what is your budget? PTFB has NEW USA made 670 boxes for $799.00.
PTFB also has new 700/800 style boxes in 10:1 for $599.00 perfect for the weekend warrior and occasional autoX on a limited budget.
PTFB also has USA made Saginaw 700/800 style NEW steering gear boxes in 12:1 ratio for $579.00
Yes you can get cheap remaned boxes but the problem is all the parts get mixed and matched, NOT good when are talking about parts that wear together, in the end they are still just cleaned up used parts and not matched to boot, you would be better off finding a used one and having it rebuilt BUT in the end the time it takes to find what you want + the cost of it + the cost of shipping a 30 pound item multiple times + the cost of the rebuild you will spend as much or more than a brand new box without having to hunt down anything, not to mention the added cost of extra parts to fit a modern fast ratio box into an older car.
Now a 600 series box will also need extra parts to fit pre 81 GM cars as they are only made in the modern version, all in all to upgrade a pre 81 car to a 600 series box it will cost about $930-$950 with shipping.
However PTFB has 700/800 style built with the splines and fluid fitting to match you ca.
69cutlassrkt
09-22-2021, 05:37 AM
Idk if I'm missing something, but sweet mfg is about 1530 dollars a box.
79T/Aman
09-22-2021, 05:45 AM
I did say a 600 series box is minimum $800.
Sweet does not manufacture those boxes 100%
PTFB has 600 series boxes for street applications from $799 to custom race applications at $2600
69cutlassrkt
09-22-2021, 06:32 AM
I see what you're sayin.
Can't wait to put the new one in. Figured I'll do it now while I change the oil pan and lower the engine. It's got an old 800 agr steering box on it right now.
79T/Aman
09-22-2021, 06:49 AM
Thank you sir.
79T/Aman
09-24-2021, 02:45 PM
Pitts64 I'm afraid I have to set the record straight here the 670 box is not a Vega box and Pintos didn't use steering boxes and if they did it would not have been a GM Saginaw box.
Claiming that Lee rejects 60-70% of boxes and sending them back !!!??? In order to do that they would have to open them up which means they could not send them back!!
New Delphi boxes are not even made anymore. GM sold Delphi to Borg Warner almost 2 years ago.
$638 for a rebuilt box is not that great a value.
No one get me wrong not trying to discredit Lee but let's not try to discredit other top notch manufacturers.
FYI the old man Lee passed away years ago the Lee name is just a business name now. And the early days of racing are as old as human kind.
69cutlassrkt
10-06-2021, 08:26 AM
Borgeson said it's neither an 800 or 600 series box that it's their own box.
dontlifttoshift
10-06-2021, 09:16 AM
K.....?
I've had both the Borgeson and the Delphi 600, in the same car, with no other changes, and stand by my statement. Did you install it yet?
79T/Aman
10-09-2021, 08:39 AM
I know from my own the new Lee box is better then the old Lee boxes I've bought. This new box is amazing. When was the last time you put one on your car?
Your right I shouldn't of passed that bad information on about how they send back all those boxes. There is no way that could be true..
This 800 box is amazing.. https://leepowersteering.com/collections/gearboxes/products/saginaw-800-gearbox-14-gm-classic-cars
This isn't Fakebook !!
69cutlassrkt
10-10-2021, 02:28 AM
K.....?
I haven't installed it yet. I returned the borgeson and got a 600 series box from protouring fbody. I received the new box quickly within a couple of days I think. I'm out 50 dollars on the old one. The thing is I wanted and paid for a 600 series box, so I returned it since it was not. Ridetechs webaddress on the steering box page says, 600-series. I can tell that the 600 box is lighter than the borgeson.
viperman
10-15-2021, 12:24 PM
In the market for a new box myself...DId the Iroc box from autozone, better than stock, but want more. I am not sure were this thread landed, but looking for bolt in, high effort. Will probably replace pump and go with a remote res. I watched the Jeff Smith Lee video on youtube, sounds like the 12.7-1 or 16-1 variable are the ones to go with....I was trying to go all in at around $1200.....How does the DSE box figure into the mix?
79T/Aman
10-15-2021, 05:45 PM
The PTFB 670 12:1 is $799.00 standard is medium effort, an high effort is available but not something I would recommend with large front tires and a fair amount of positive caster.
Josh@Ridetech
10-18-2021, 07:54 AM
Looking at our site, I show it listed as replacing an 800 series box. There is a rag joint needed to make it mate up to 600 series gear but the box itself is an 800 replacement (just tighter ratio). Fitment wise, I can't say I've had any issues with it being too big to fit. If you see a spot saying that it's a 600, can you please send me the link so I can have it fixed? On an actual 600 case, I can't say I know where the best place to look is. You could try calling Borgeson directly?
protour_chevelle
10-18-2021, 11:44 AM
As an outsider looking in and checking the website, the reference to the rag joint to fit a 600 series box to me is suggesting the box is a 600 series because the web page is suggestiing I need the additional part to make it work.
side note, 800 series box I had to grind to clear my PS pulled on my ls swap. A 600 series I do not have to touch the box to changes belts.
79T/Aman
10-21-2021, 01:35 PM
The suggestion that it needs a rag joint to fit is because the spline count is different, most vendors don't know why thing are the way they are.
protour_chevelle
10-22-2021, 03:59 AM
I understand that, All Im getting at is if it omitted the 600 series verbiage and simple a suggested rag joint, it would remove the ability for someone to assume it was a 600 box. It would be nice to have the box stated as what series it was. When I was looking for a box I kept looking as the info wasn't there.
Rb_69camaro
06-27-2022, 09:49 PM
Which box did you go with? Ratio and valve? Im looking around. How does it feel/handle? Thx
69cutlassrkt
07-04-2022, 07:08 AM
It says 600-series-steering-box in the web address - https://www.ridetech.com/product/borgeson-12-7-1-600-series-steering-box/
I told the guy on the phone at ridetech this also and mailed the piece of paper with the return showing where it says 600 series.
Replacing an 800 series box is vague. I think the description was copied from borgeson and everything else was left the same from when y'all used to sell turn one boxes. I think that's why one of the tags is turn one.
69cutlassrkt
09-22-2022, 08:12 AM
I had submitted a review to ridetech on the steering box about a month or 2 ago. I guess they did not approve it since it was not positive or enough stars. It was pretty much the same as what I had said in my previous post. Nothing on the web page has been updated. Still has 600 series and turn one tagged on the product page. It is false/misleading advertising.
pitts64
09-23-2022, 11:17 AM
We always thought the 600 is for drag racing, I don't know why they would of put street on the description. I guess they made them stronger for street use.
I have the Lee blueprinted 800 series box, in the 14:1 ratio with 30-pound torsion bar. I like the Grant 13" steering wheel. It's perfect with the 14:1 ratio.
Tuning alignment on street cars, I keep the camber as close to zero as possible but crank up the positive caster. I have my 69 el Camino set for 7.5 to 8 degrees Positive caster, I have the camber set to about a tenth of a degree negative to the negative.
When my car pulled to one side I used cross caster but when it slowly drifted to the right, I used cross camber to correct that.
I have Marks Stage three set up with the Howe .9 and .5 ball joints and the hex adjustment couplings. These make tuning simpler.
79T/Aman
10-03-2022, 02:51 AM
[QUOTE=pitts64;1382723]We always thought the 600 is for drag racing, I don't know why they would of put street on the description. I guess they made them stronger for street use.
I believe there is confusion here with the 625 Vega steering gear that was the go to drag race box, not at all the same as an aftermarket 600 series.
