View Full Version : Bellhousing Adaptor Plates
79TransAm
01-01-2006, 02:18 PM
Does anyone know of any companies that make bellhousing adaptor plates to bolt an older motor to a newer trans? I'm looking at dropping a 400ci into my 87, but I dont think it will bolt right up to the trans, any ideas? thnx in advance. Also does anyone know if I could fit a 4L60E in there inplace of the 700R4?
Patrick
01-01-2006, 06:13 PM
Try Advance Adapters or Novak Conversions. They make a ton of stuff for 4x4 engine/trans swaps. For example, I am running a SB 350 mated to a Ford T18 in my Jeep.
http://www.advanceadapters.com/
http://www.novak-adapt.com/
Maybe they can help.
andrewb70
01-01-2006, 07:15 PM
If you want to bolt a Pontiac engine to a modern overdrive trans, then the simple solution is to use a 200R4 from a Buick Grand National. They can be built very strong and have a BOP bellhousing pattern.
79TransAm
01-03-2006, 03:48 PM
i already got all the parts to rebuild the 700... If i end up getting a different trans ill just use one of the T/H350's i got laying around.
Steve Chryssos
01-06-2006, 08:19 AM
Give a call to Bowler Transmissions. I just spoke to Mark there about an adapter for a 4L80E to BOP block. Says an adapter for that application is about $240. Crank to flexplate spacer, bellhousing dapter and hardware. Hopefully he has one for your application as well.
http://www.bowlertransmissions.com/
RR#4 Box 148
Lawrenceville, IL 62439
Main Phone: (618) 943-4856
Fax : (618) 943-3690
