BuddyP
01-01-2006, 07:48 AM
What driveshaft are you guys using in your 1st gen camaro's with LS1/T-56 swaps? What rear end are you using with that setup?
Buddy-
More than likely, you're going to need a custom driveshaft that mates to the spline count on the T56 and whatever rear you end up running. As far as what rear to use, that depends on what you're looking for- a 12 bolt would be an easy bolt in, while a Ford 9" would give you easier gearing changes. Even a 10 bolt would be fine if you aren't doing to much to up the HP on the LS1.
Bob
