View Full Version : Firewall pass through
Build-It-Break-It
07-15-2021, 01:48 PM
Just wanted to post this up. I was looking for a cleaner way to pass my harness through my firewall. I contact the owner of the business and showed him a design and he was able to produce it. Hopefully this helps others. I am not affiliated with the business or owner.
https://sharpe-performance.myshopify.com/products/psi-style-wiring-harness-billet-bulkhead
Just 1 More
07-16-2021, 06:10 AM
Thats nice. What size is the hole?
Tsaints1115
07-16-2021, 06:16 AM
It's a good looking way to do it for those not using a bulkhead.
NorCal-SS
07-16-2021, 01:24 PM
I’ve been looking for something like this. Just ordered a ceramic coated one. Thanks for the link!
Build-It-Break-It
07-16-2021, 06:34 PM
I was going to use a bulkhead but I wanted to keep the install simple. The bulkhead ads a failure point in my opinion. Vibration, moisture etc etc. The one I posted keeps it simple and clean and you can pass the wiring through the firewall easy in case of a motor swap. I'm glad it helped some of you.
Ahmad
Just 1 More
07-17-2021, 06:40 AM
I still want to know what size the hole is
It shows in the link. I remember reading it but don’t recall the size for sure. 1.125” IIRC
Edit:
1.2” for a 2” hole
Just 1 More
07-17-2021, 07:08 AM
Yep, I missed it "Center hole is 1.2 inch diameter"
Steve68
07-18-2021, 04:25 AM
Ahmad
Mil Spec Cannon or bayonet style connectors will not give you any of the things you described above, Aerospace and Military, plane manufactures have been using them for years, many years, Steilow, used them years before on one of his cars, cost and knowing how to terminating wires and pinning the connector is the only set back,
Build-It-Break-It
07-18-2021, 07:19 PM
Once you price out the multiple Crimpers, the mil spec connections, and hope that you accomplish the job properly the juice isn't worth the squeeze for me personally.
I've worked on diesel trucks, school busses and heavy equipment for 20 years before I became a high school teacher and I can tell you first hand the connections come loose more often then not or get water/ coolant damage.
Some things are better left to the military and high end car builders. I just want a cool hot rod.
dhutton
07-19-2021, 03:59 AM
Basic reliability engineering says the fewer components and connections in a system the more reliable it is.
Don
joeko23
07-19-2021, 04:56 AM
You guys think that’s air and water tight? I’m thinking it can’t be. The wire loom is ribbed, surely air and water can pass through that grommet. Unless you silicone the backside I guess. Looks nice though.
dhutton
07-19-2021, 05:43 AM
It doesn’t need to be air and water tight imho. The car isn’t otherwise hermetically sealed. Not a whole lot of water flows down the firewall imho. Wouldn’t take much to make it more water tight if it’s something that causes you to lose sleep. No firewall grommet on convoluted tubing is likely watertight.
Just my two cents,
Don
