View Full Version : Bolt-in Floater Rear end for GM G Body Cars??
Malicad
07-13-2021, 07:25 AM
Hi everyone, after building street/strip cars for many years, I am building my first official "pro-touring" car, a 1979 Malibu wagon. I have the front suspension sorted out, but I have not been able to find a manufacturer for a rear axle. I want a Ford 9-inch, full-floater style, that's a bolt in for the GM G Body cars. I'm not going to professionally compete with this, but will be taking it to local SCCA and road course events on rare occasions, so I'm concerned with brake pad knock back, hence my decision to go with a full floater. Anyone know of a rear axle manufacturer I can use?
dontlifttoshift
07-13-2021, 11:33 AM
Did you try Strange?
Jonathonar89
07-13-2021, 12:39 PM
https://millerbuiltusa.com/
Malicad
07-13-2021, 08:23 PM
Hi Donny, thanks for the suggestion. I did look into them. Their pro touring kits require 35 spline axles...too big for my 31 spline center section. Also, they only offer wheel studs in either 1/2" or 5/8", which won't match my 12 mm fronts from my C7 Corvette hubs. Not a deal breaker, but annoying to have dedicated front and rear lugnuts.
130fe
07-14-2021, 12:53 AM
Have you called GearFX? They make the rears for DSE, maybe they can make you a rear using the DSE floater (that uses the corvette style components).
Malicad
07-15-2021, 01:28 PM
Thanks, guys. I appreciate the replies. That Millerbuilt setup looks good. I'll check out Gearfx, too...
Malicad
07-16-2021, 02:46 PM
Just found out I can get floater axles with 2 different spline counts on the same shaft. Who knew??
jknight16
07-16-2021, 06:36 PM
True, I was told they could build me axles that would use the existing 29 spline True-trac that I have with the c7 spline count bolted to the Miller Built housing ends. I’m not racing so the 29 spline should be sufficient, just haven’t pulled the trigger on that stage of scope creep.
Number1
08-22-2021, 06:43 PM
What suspension are you running on the front?
Rb_69camaro
02-01-2022, 04:24 PM
I want to bring back the topic of Floater kits. What choices do we have for manufacturers? Someone said Strange, but they cant even provide that right now...they have orders that have been waiting since last summer(including me). Has anyone been able to get a Ford 9" with a floater kit in the last 9 months or so, and if so from whom? Does Currie do their own forgings and machine work in house?
dontlifttoshift
02-02-2022, 05:39 AM
Miller Built is the answer. I didn't bring it up to the OP as he wanted a whole housing. Buy a housing with torino ends and bolt these on https://millerbuiltusa.com/big-ford-base-kit/
protour_chevelle
02-02-2022, 06:53 AM
I did a strange 9" with weld on millerbuilt floater ends. Jay was top notch to deal with.
CSG
02-02-2022, 07:18 AM
I did a strange fabricated housing from Millerbuilt as well. I gave them all my specs and they provided everything except the center which I already had. Really happy with their work and communication.
Alwhite00
02-02-2022, 07:41 AM
Did you try Quick Performance?
