derekf
07-10-2021, 11:47 AM
69 El Camino.
I have realized that the tire-to-fender-lip dimension was much larger on the pass side than the driver's - ~3" vs 1 1/2"-ish. Initial thought was that I'd gotten the body misaligned to the frame so with a bunch of pushing and prying and the use of one of those hydraulic thingies they sell at Harbor Fright I was able to get the tire-to-lip dimension to 2" on the driver's... but the frame mounts don't line up so well underneath now so I'm probably doing bad things there.
Then I realized that the wheel-to-frame dimension also differed between the side: about 1" on the pass side, about 2 1/2 on the drivers -- so the axle itself is offset.
It's the original axle. Lowers are tubular BMRs, so unlikely they're bent; uppers are adjustable but I can't fathom how they'd be able to move the axle over.
I have NOT swapped the wheels between the sides to see if I somehow got mismatched offsets (they're Soft 8s which only come in a single offset so probably not).
Is this "normal" for the 69 A-bodies? Do I just need to (ugh) put a spacer on the pass side and call it good?
