View Full Version : Aluminum 5.3 lc9
66larkgs
07-03-2021, 02:52 PM
All aluminum lc9 with all new cam,rod and crank bearings. Crankshaft polished , New rings,fresh hone, .585 lift cam, new ls7 lifters new lifter trays,new timing chain,gears ,oil barbell upgrade. New head gaskets,ARP head bolts . Pac 1218 springs,trunnions upgrade , new valve seals. New rear main seal. New timing cover gasket, new oil pump. Never been ran since assembled. I can install the stock oil pan and pickup(currently not on)Built for a project And need to sell to fund a transmission for my nova. Will include stock gen 4 intake and ecu. $2700
Also have a gen 4 6.0 rec port head (cast iron block) for a $1000. Needs to be rebuilt.,think it had a bad lifter. Located in mass
On me if interested and I can send some pictures.
jwcarguy
07-03-2021, 05:10 PM
Paul, what condition are the blocks in? Being from Mass.
you looking at shipping at all?
Thanks, Jeff
66larkgs
07-03-2021, 06:30 PM
I would ship.blocks are in good shape.on the lc9 I tapped everything and hot tanked the block. The lc9 block was hot tanked and cleaned.
KAN KAN Speedshop
07-04-2021, 10:51 AM
PM Sent
66larkgs
07-07-2021, 08:46 AM
190195190196190197190198190199
66larkgs
07-07-2021, 08:47 AM
190200190201190202
66larkgs
07-08-2021, 02:50 PM
190222
Bump
66larkgs
07-15-2021, 04:36 AM
Price drop to $2500. I am putting the timing chain /oil pump and covers back together and will take updated pictures
66larkgs
12-02-2021, 06:43 PM
Bump b/0
chevelletiger
12-04-2021, 02:27 PM
shipping 6.0 to 92707 zip thanks
66larkgs
12-04-2021, 02:48 PM
6.0 is sold. The all aluminum 2012 5.3 is left. I can ship through fastenal $2500 shipped to you local fastenal
66larkgs
12-27-2021, 05:20 PM
All aluminum lc9 5.3 is available. 58x gen 4 . new rings,main,rod and cam bearings all new. New timing chain and gears. New Arp head bolts,new ls7 head gaskets and lifters. Trunion upgrade,pac springs, new valve seals,.585/.585 camshaft. DoD Deleted and 3 bolt camshaft installed. Make an offer
jwcarguy
12-27-2021, 05:24 PM
All aluminum lc9 5.3 is available. 58x gen 4 . new rings,main,rod and cam bearings all new. New timing chain and gears. New Arp head bolts,new ls7 head gaskets and lifters. Trunion upgrade,pac springs, new valve seals,.585/.585 camshaft. DoD Deleted and 3 bolt camshaft installed. Make an offer who built it?
Shipping to Las Vegas, NV (Fastenal isn't shipping between coasts right now ??)
Thanks, Jeff
