Jimrowe0
06-16-2021, 05:04 AM
Sold my protouring Camaro project as a roller so have the following parts left over for sale:
TEXT OR CALL: 919-523-6968
Almost all these parts are brand new with receipts, expect the engine which was pulled from a running/driving 4th gen fbody with less than 10K miles on build:
Engine and Trans: $6500 shipped
LS1 converted to 383 stroker (torque monster)
Under 10k miles
Compression: 11:1
Scat forged 4340 crank
6.125 forged I beam rods
ARP rod bolts
Autotec Forged pistons 1000727 3.905 bore, -3.3cc dome with 2 valve reliefs
Total seal piston rings
Trick flow 220 heads
Pat G cam
Comp cam ultra pro roller rocker arms
Holley 302-1 oil pan
ARP timing cover, crank, cam sensor hardware
MSD plug wires
ARP head studs
LS6 intake manifold ported
LS6 throttle body ported
42lb/hr green top injectors
Full fbody front drive set-up
SFI underdrive crank balancer
Transmission: Stage 3 rebuilt 4l60e with B&M 70442 3000rpm stall with lockup
New Holley 20-142bk LS A/C ACCESSORY DRIVE KIT - INCLUDES SD508 A/C COMPRESSOR, TENSIONER, & PULLEYS- BLACK FINISH: $550 shipped can include a set of full Fbody accessories to go with this for another $250.
Rear end rebuild kit for a 10 bolt (new): $750 shipped
Motiv 3.42 R&P gears
New direct axles
Auburn posi unit
Installation kits
All fluids etc.
Interior (new):
Holley 6.86 pro digital dash with custom customworks bezel (bezel would need powdercoating): SOLDD
B&M quicksilver ratchet shifter in black: $260 shipped
1970-1973 New ACC Essex carpet with tail for auto transmission: SOLDDD
1970-1976 Camaro Newly rebuilt and painted OEM gm tilt column: $650 shipped
Exterior (new):
Anvil auto front ended bumperettes: SOLDD
Anvil auto rear fiberglass bumper: $400
Under 10k miles
Compression: 11:1
ARP rod bolts
Pat G cam
MSD plug wires
ARP head studs
New direct axles
Auburn posi unit
Installation kits
All fluids etc.
Interior (new):
Exterior (new):
