View Full Version : FAST xfi power adder wiring question
pushrod243
12-30-2005, 05:03 PM
I am hooking up a single stage nitrous system on my 502. I am a little confused probably just being over cautiuos but here's my question.
I hooked the solenoids up through a relay to trigger the relay It says
"The pink wire on pin E is the enable wire. Connecting this wire to +12V enables the power adder system. This is typically connected to a toggle switch."
then the blue wire w/ white tracer is the ground that triggers the relay
Does that mean the toggle switch is to be used as a gate for the pink wire or does it need 12v+ on one side and the pink wire on the other. I just want to make sure before I hook 12v to the computer and fry something. Anybody got any ideas I called fast but I think they are closed until after the 1rst.
ProStreet R/T
12-31-2005, 08:32 AM
Yes the Nitrous arming wire gets 12v, all the others activate relays via ground.
pushrod243
12-31-2005, 04:09 PM
thanks i kinda figured it had to be that way but kinda over cuatiuos when it comes to hooking 12v to he computer
