jpierson77
05-22-2021, 12:37 PM
Full Chassisworks protouring suspension for 1967 1968 and 1969 Camaro
I bought this suspension in 2012 and installed in the car, the project stalled and the car has sat inside since 2012. I am finally getting the project going again. The car is going to be taking a different path now and so I have removed this suspension and I am looking to sell it. This has been powder coated and installed in the car but never driven.
What you are gettting:
Front Suspension
Chassisworks complete front subframe powder coated black
http://www.cachassisworks.com/p-696-camaro-67-69-f-body-nova-68-72-bolt-on-front-frame-clip-without-suspension.aspx
Chassisworks g-machine front clip suspenison
http://www.cachassisworks.com/p-3661-g-machine-clip-front-suspension.aspx
Chassisworks LS motor Mounts
http://www.cachassisworks.com/p-3801-side-motor-mounts-billet-aluminum-chevrolet-ls-forward-offset.aspx
Chassisworks front strut bars (does need firewall plates and tabs available from Chassisworks)
http://www.cachassisworks.com/p-2693-camaro-67-69-f-body-exact-fit-front-struts-1-58-4130-steel.aspx
Chassisworks G connector Support
http://www.cachassisworks.com/p-3116-camaro-67-69-firebird-67-69-f-body-center-g-connector-support-bolt-in.aspx
Chassiworks bolt in subframe G connector
http://www.cachassisworks.com/p-3108-camaro-67-69-firebird-67-69-f-body-subframe-g-connector-bolt-in.aspx
Chassisworks Drive shaft loop
http://www.cachassisworks.com/p-1593-driveshaft-safety-loop-for-g-connector-center-support.aspx
Varishock bearing eye double adjustable Coil Overs
http://www.cachassisworks.com/p-930-varishock-coil-over-bearing-eye-top-bearing-eye-standard-base-double-adj-425-travel.aspx
Chassisworks T-56 Trans crossmember
http://www.cachassisworks.com/p-2214-camaro-67-69-nova-68-74-transmission-crossmember-tremec-t-56-6-speed.aspx
Rear Suspension
Chassiworks Canted 4 Bar G-link with pivot ball
http://www.cachassisworks.com/p-1299-camaro-67-69-firebird-67-69-gm-f-body-g-link-pivot-coil-over-suspension.aspx
You would need to buy part numbers 5355, 5366 and 3148-263.38-094, these are the frame rail brackets and bolts. These are welded in my car and are not salvageable.
Chassisworks Fab 9 rear end housing for splined sway bar, powder coated black
http://www.cachassisworks.com/p-803-camaro-67-69-nova-68-74-g-bar-mild-steel-narrowed-fab9-with-arb-mounts-with-late-big-ford-sealed-ends.aspx
Strange Engineering 3rd noular 3rd member with Eaton Trutrack, 3.89 gears, 31 spline axles
Chassiworks splined sway bar
http://www.cachassisworks.com/p-1310-camaro-67-69-firebird-67-69-nova-68-74-g-bar-splined-anti-roll-bar.aspx
Varishock bearing Double adjustable coil overs
All of this new would cost over $14k! Asking $10,000 buyer pays shipping, or depending on location we might be able to arrange a meet halfway delivery deal. Located in Fort Collins CO.
I also have a Baer Pro + 14" Front and SS4+ 13" Rear (Red) Brake kit and stainless headers that I had intended to re-use however if someone is looking for a package I would also sell those.
Front Suspension
Rear Suspension
