transam9973
05-16-2021, 08:14 AM
https://static1.pt-content.com/images/pt/2021/05/350600_L_15a832e8e40343aaa86718976626666-1.jpg
The advantage:
The Unser Edition is an enhanced G-Comp front end with the following components:
Subframe features a chassis brace machined from billet aluminum
The billet chassis brace holds the upper shock mount
The upper shock mount position is adjustable, permitting use of multiple length shocks - Adjust your shocks in minutes!
The new upper shock mount provides clearance for springs with large wire diameter
Upper control arm is designed with an additional 3° caster over standard G-Comp arm
Lower control arm has a recessed front strut to increase tire clearance
Up to 275/35 R18 tires can be used in competition
Steering arm is designed for a 20% quicker steering and increased Ackermann
Overall increased camber gain over standard G-Comp kits
Kit comes with a 0.250" wall - 1-1/4" O.D. sway bar
Allows for a large range of front ride height adjustment, working with a wider range of shock lengths and strokes
Standard features:
Complete bolt-in front frame assembly replaces stock subframe
Will work with 14" through 16" long shocks - not included
Multiple hub and brake packages available - not included
Choose your brake kit and coil-overs from the options listed below
Anyone have experience with this subframe in a 2nd gen for autocross?
How does it compare to DSE or Speedtech?
The advantage:
Standard features:
