View Full Version : 19" wheels
Canadianwraith
05-06-2021, 01:45 PM
Tried to order wheels today, 19x9.5 and 19x11. Offsets are +5 and +10. 69 Camaro mini tubbed I don't have my rear yet, going 9" after wheels are in place. Stock subframe. Is there any reason these won't work?
swain
05-06-2021, 01:57 PM
It will rub when you turn. You might be able to make it work with the Ride Tech True turn.
Canadianwraith
05-06-2021, 02:15 PM
Thanks for the reply Jason. I'm good with having to purchase different components if needed. Being that the rear has not been ordered a +5 offset shouldn't matter correct?
68Formula
05-06-2021, 03:09 PM
I wouldn't order wheels until you have the rear in place and can measure clearance. Front depends a lot on the total setup. You need to measure fitment to some some baseline. Will be hard to fit a 9.5" on a +5mm offset, and I think the minimum tire for that size would be a 255/30. And unless you run a LOT of static camber and fix the camber gain, you'll rub on the fender. Most fit a 245 with the correct offset, improved camber gain, and aggressive street alignment.
Suggest you do a lot of research on this forum and know your suspension setup, before you spend $$$ on wheels.
Canadianwraith
05-06-2021, 03:14 PM
See every other thread says get you wheels and tires first then measure for rear end
68Formula
05-06-2021, 04:18 PM
Brainfart. Wasn't thinking custom-width specified narrowed rearend.
Canadianwraith
05-06-2021, 04:38 PM
Ya no worries, still great advice. I really want to get my car down on wheels
