eviltwin_1987
04-27-2021, 04:13 PM
I am having an issue where I don't have working power brakes or power steering. Hoping for some advise on what to look for. The truck runs and steers like it has manual steering and manual brakes. The pedal is nice and firm and returns no problem. I have bleed the system with the engine off, turning the wheel back and forth a hundred times while pumping the brakes. This brought the fluid level down and then I refilled it. But I have no P/S or P/B. Bleed it with the engine running as well with no difference. After topping off the reservoir, bleeding it with the cap off would cause some fluid to rise in the reservoir and out the top. The pump is silent during all of this operation so I'm assuming its pumping fluid. Here is my setup.....
-'53 Chevy Truck
-'12 CTS-V LSA engine, power steering pump and brembo brakes.
-S-10 steering box.
-Astro van hydroboost UNDER the floor with C3 corvette master. The hydroboost is oriented with the pressure lines facing down.
-custom crimped -6 hydro lines, no AN lines
-return for both hydroboost and steering box are Teed together under the pump with one line that goes up to the reservoir.
The brakes in the CTS-V worked flawless before I took that car apart. The hydroboost was on a previous truck of mine and also worked without issue.
I have read about people not Teeing the two return lines and tapping a second hole for separate returns in the reservoir. Is that something that would cause this issue? Could it be an issue that the hydroboost is the lowest point in the system so its has air that cant be pushed out? Any help would be greatly appreciated.
-'53 Chevy Truck
-S-10 steering box.
