View Full Version : Hydroboost/G-Brace Interference 2nd Gen Firebird
c_k_115
04-25-2021, 06:41 PM
Good evening all,
I am coming close to finishing up the engine bay on my 78 Trans Am, and am running into an issue which looks like the adjustable G-Braces are going to hit the proportioning valve/lines of the hydroboost. Has anyone else encountered this? If so, was moving the proportioning valve and re-plumbing it enough to get the braces clearance? I tried a quick search, but couldn't find any others in the same predicament. Thanks for looking!
187615
c4racer2
04-25-2021, 08:16 PM
I would ditch the hydro boost. Personally.
SPG
04-25-2021, 08:38 PM
Thats not really helpful for the person asking the question now is it lol
c_k_115
04-26-2021, 05:36 AM
I definitely like the hydroboost, so would rather keep that than the G braces. I'm pretty sure relocating the proportioning valve will work, otherwise I'm sure I could get someone to modify the G braces to curve up over the proportioning valve.
c4racer2
04-26-2021, 09:30 AM
I have those braces and a fully manual brake set-up. There isn't a lot of room. You might have to decide if you like your brake set up or the braces more and go from there! Is kind of where I was going with my comment above.
And yes - by all means I would try to bend up some tubes to make it work if you can. I found it easier to have the braces off to get the tubes all bent up - but just do something to reference the location of the tubing so you know what the keep-out space is.
- - - Updated - - -
Hydratech®
04-27-2021, 07:09 PM
Both Baer and Wilwood now have super short master cylinder designs now available, with brake line connections available on either side, coming in at about 6 3/4" installed length. They aren't cheap, but are a helluva lot shorter than the 8 1/4" length MC you currently have installed. This will likely give you the room you need to install your G brace.
:6gears:
