nzcarguy
04-10-2021, 10:57 PM
Hi All
Looking for any ideas, the other day I forgot (DA) to disconnect my battery and shorted the starter cable/battery feed. No fuses blown.
I disconnected the battery earth, left the positive on and found the battery dead. recharged, then replaced the battery but I have I have .2 mili amps draw without the earth connected.
LS3 crate with GM ECU in first Gen Firebird.
The wiring has 4 separate circuits from the battery.
1) OEM wiring harness - lights etc
2) Vintage Air
3) ECU
4) Alt/starter
I have disconnected each circuit and measured the milli volts each time. No change for 1,2.4 leaving only ECU.
Has anybody seen this problem and where on the ECU should I be looking for a short?
Thanks in advance.
2) Vintage Air
3) ECU
4) Alt/starter
Thanks in advance.
