View Full Version : Tank vent question
1985olds
04-06-2021, 04:24 PM
Good evening,
I'm in the process of converting a tanks inc tank to be used with a zl1 fuel module. I am using a Rick's weld in adapter. When I cut the tank for the Rick's piece, I had to cut off the vent. My question is can I weld a new vent nipple on the filler neck to vent the tank? Thank you.
andrewb70
04-07-2021, 06:44 AM
....My question is can I weld a new vent nipple on the filler neck to vent the tank? Thank you.
Yes.
JohnUlaszek
04-07-2021, 08:48 AM
One on the filler neck is good, but it can be hard to fill the tank without a second port located on the tank itself. I’d ask the manufacturer for guidance.
1985olds
04-07-2021, 04:59 PM
Thank you. I tried calling tanks inc today and they were at lunch. I'll try again tomorrow.
NorCal-SS
04-08-2021, 01:13 PM
Since you’re welding in the Ricks adapter, is there enough room on the adapter plate to weld a 90 deg nipple to use as a vent?
