View Full Version : 1967 Chevelle Pro-touring stance suggestions
Tmicallef
04-01-2021, 04:58 AM
Hello everyone! 1st time poster here lol.
Here's a pic of my 67 Chevelle. The car currently has 17x8 rear...16x7 front. Tires are 255/50/17 and 225/55/16. The car currently has a stock 12 bolt rear end and 4-corner power assisted drum brakes and factory suspension. I want more of a pro-touring look and need advice on what would look the best along with tire size and backspacing. I really like the look of the 68 posted earlier with the 20/19 setup but not sure if I would have to same amount of room on my 67. I also like the stance of the black pic I posted.
Any advice and ideas would be greatly appreciated. If I only had Photoshop to whip up some different looks lol.
67-LS1
04-01-2021, 07:47 AM
I have 17s and 18s on my 66 which is very similar to the 67 and I like mine low. I have 2” dropped spindles in the front and 2” dropped springs with a 1/2 coil cutoff so roughly 3” lower. I like the stance now. But there have been issues.
The drive shaft rubbed in the tunnel in the back so I had to build a new taller tunnel all the way through the back seat. And I had to modify the seat springs to clear it.
in the front the out side of the tires rub the inside of the fenders sometimes. This is partially due to the disc brakes adding to the width. When I change wheels I’ll change the offset to eliminate this issue.186516186517
NorCal-SS
04-01-2021, 09:47 AM
As a fellow 67 owner and lover of a low stance I think stance and drivability are a compromise on these old cars. IMO air ride gets you the best of both worlds. Lift it a little to drive and slam it when it’s parked. Anything other than that is a compromise between to low to drive without issues and too high when parked for my taste. FWIW I’ve settled on function over form over the years and plan on running extended travel coil overs on my current project, accepting that it won’t be quite as low as I would like but will provide the best handling and ride quality without any binding or interference issues (hopefully!)
SPLATT71MC
04-02-2021, 08:53 PM
I really like how your car sits as it is. I would be upgrading the brakes though.
Tmicallef
04-11-2021, 10:17 AM
Thanks Splatt. When I first bought the car I thought that at the very least a front disc upgrade was needed but this car is set up with a 12" booster and 4-wheel drum power assist...along with line-lock. The brakes are surprisingly good and the car feels like it has 4-wheel disc!
