View Full Version : Looking for a hydraulic pump
Vimes
03-13-2021, 08:30 PM
This is going to be an oddball question, off the main direction of this board, and I really don't expect an answer, but I'd like to know if anyone is aware of the existence of a hydraulic pump. What I'm looking for is a "sandwich pump" that will bolt between a GM small block engine and auto transmission to act as a PTO drive. Ideally, it would be no more than 2 inches or so wide, and connect between the flexplate and torque converter for its drive power. I'd like it to be something that can be always on any time the engine is running, and generates enough force to run a 20HP load at a constant 2000RPM, whether the pump is being spun at 500RPM or 6000RPM.
Is anyone aware of such a beast? If not it'll be back to the drawing board on this side project.
andrewb70
03-14-2021, 09:42 AM
I don't know of such a pump, but I am curious what you are doing.
Vimes
03-14-2021, 02:47 PM
If I can find one, and the cost isn't too high, this would let me put all engine accessories in the bed, putting the weight just in front of the rear wheels instead of just in front of the front wheels. Just an exploratory, right now.
dontlifttoshift
03-15-2021, 12:15 PM
Would the net weight gain to the whole vehicle offset the advantage of moving less than 1% of the total weight rearward?
Vimes
03-15-2021, 04:54 PM
I would be removing the accessories as well as all bracketry, pulleys and other related stuff off the front of the engine. It would probably drop 100LBS off the front, and move it to the rear, so it would be like a 5ish percent front to rear weight shift. Trucks are very front-heavy, so this can only help handling. Plus it would look pretty slick. I already have a plan on how to do this that puts just an alternator up there, I'm just trying to eliminate that too.
