View Full Version : Gas leaking out of tank vent
NovaSF
02-12-2021, 06:43 PM
Hello everyone. I have a LS3 swapped 70 Nova with a basic return style system. Noticed a little fuel dripping under my car today after a little drive. Appears it was coming out of the gas tank vent (pictures). I then opened the gas cap and a bunch of pressure blew out of the filler neck. Weird. The drips stopped. Tank is about 60%full.
Clogged vent where it allows pressure to build then puke??? Any thoughts???
Thanks!
grease
02-12-2021, 07:59 PM
Does the vent have a roll over valve in it? If yes, it may need to be installed vertically instead of horizontally.
NovaSF
02-12-2021, 09:25 PM
Hmmmmm. Not sure. Would a roll over valve have something to do with the big washer right under the vent cylinder? Not sure what the purpose of that washer is.
NovaSF
02-12-2021, 09:30 PM
Quick search..... bingo. Sure looks a lot like this.. Roll Over Vent Valve.
184778
dhutton
02-13-2021, 05:25 AM
Needs to be vertical and above the level of the tank with no dips in hose that could collect fuel.
Don
RdHugr 68
02-13-2021, 07:49 AM
Rollover vents are more trouble than they are worth.
Twentyover
02-13-2021, 07:58 AM
But required by many vintage racing sanctioning bodies
Rollover check valve is frequently a ball check valve depending on gravity to remain open to vent. Mounted sideways, it's boned. So the question I'm having is why the tank is building pressure when functionally sealed and consuming fuel?
andrewb70
02-13-2021, 09:22 AM
Someone didn't read their Tanks Inc. instructions :-)
2yellow69
02-13-2021, 09:24 AM
Could the pressure build up be the fuel warming up? Or the engine creating a vacuum by using the fuel in a "sealed" tank? Between the fuel warming up and the vacuum in the tank the roll over check ball might be the easiest route for fuel to escape?
A long time ago when my 69 Camaro was stock someone stole my gas cap. Well, I may have left it at the gas station. Anyway, I bought a new cap, put it on and went on my way. The next night at 2 in the morning it sounded like someone hit my car with a tennis ball and set off the alarm. My neighbors and I ran outside and found nothing. It happened a few more time during the week and my buddy and I decided to stay up and catch whoever was messing with my car. A little after midnight, while we were both looking at the car, it happened again. No one was around and nothing hit my car. The next day I started investigating and found the new non-vented cap had allowed the 30+ year old fuel pump to collapse the top of the tank. As the night cooled down the tank slowly released vacuum and the top of the tank would "pop" partially back into place. A new tank and sending unit with a VENTED cap solved the issue. It was amazing that the fuel tank was absolutely destroyed by putting the wrong gas cap on.
NovaSF
02-13-2021, 12:05 PM
:screwy: I guess I’ll have some questions come Monday for the dude who did the fuel system set up. Uuurrrrrgggghhhhhhhh.
Took out the valve, tested it, it’s functioning as it should. The temps here don’t swing too much in SF but there have been some highs and lows lately when I’ve been driving (~ 25 degrees), don’t know if that matters.
Gonna trim the tube a bit so there are no flat spots and it’s perfectly vertical and make a little bracket. Then test and WE SHALL SEEEEEEEEEE.
Thanks for everyone’s input, this site is very therapeutic at times as it helps from going down the rabbit hole into what the hell is wrong this time madnesss....
andrewb70
02-13-2021, 12:13 PM
Also, why is there a hose clamp on what looks like an AN fitting? On the center port of the regulator/filter...
NovaSF
02-13-2021, 02:54 PM
Here’s a pic of that hose clamp
NovaSF
02-13-2021, 02:57 PM
184806Gonna go test later today🤞
2yellow69
02-13-2021, 03:55 PM
If I remember correctly, the center port is the return to tank line. It's been a bit since I've worked on my car. That fitting is probably a barbed fitting to AN.
andrewb70
The inlet AN adapter is loose. The one that's offset.
NovaSF
02-13-2021, 10:35 PM
AndrewB70.... everything on the offset seems tight and no leaks. Am i missing something obvious??
blitzer454
02-14-2021, 02:23 PM
I think Andrew is referring to the gap in the hose fitting. There should be no gap like the other fitting.
184833
andrewb70
02-14-2021, 02:46 PM
184833
Yes...that.
Hotwire
02-15-2021, 06:20 AM
I ended up pulling my Tanks Inc rollover valve (running their tank in my 64 Chevelle). The vents they have in the tank cause too much fuel to run up through the vents constantly triggering the rollover valve and allowing pressure to build in the tank. I've had so much pressure build it was pushing fuel out of the sending unit/fuel pump access gaskets.
If you want to keep the rollover valve I highly recommend installing a burp tank inline on the vent so that fuel will not get to the rollover valve. I plan on getting an ebay PCV catch can and converting it to burp tank duty then reinstalling rollover.
NovaSF
02-18-2021, 04:39 PM
Thanks.. I’ll investigate
eville
02-19-2021, 12:58 PM
I believe it's that same roll over valve causing a fuel odor on my car under load. I have a II Much Fab. vent on the bench waiting to go in... part of me thinks I should throw in the towel on this Tanks Inc and get a Ricks restomod with the internal regulated pump.
Hotwire
02-24-2021, 04:54 AM
The II Much Fab should solve the problem? I mean, if you want to throw a grand at getting another tank, go for it, but you already have a solution to the problem..
dhutton
02-24-2021, 06:15 AM
I don’t think a iimuch vent will fix a tank that has a lousy vent design. Garbage in, garbage out....
At least this has been my experience.
Don
JohnUlaszek
02-24-2021, 07:09 AM
A properly installed IIMUCH (https://www.iimuch.com/collections/fuel-differential-vents) vent will fix this. Its unlikely you will need to replace the tank.
dhutton
02-24-2021, 07:19 AM
Hi John. Didn’t you do a bunch of work with Ricks to get their tank vents redesigned? The reason I ask is I have one of their older vent designs and it stinks with your vent.
Don
dhutton
02-24-2021, 07:23 AM
This is what I’m referring to. According to instructions the tank vent will need to be redesigned for the iimuch vent to function properly.
If the fuel tank does not have a vapor dome, properly located vent ports(s), or the application, such as off-road or road racing, could cause the fuel tank vent port to be submerged, relocation or additional ports may be required. If the application has two or more vent ports they can be joined with a T fitting and a single hose routed to the VSR. Failure to address this could result in liquid fuel bypassing through the VSR, pouring out on the ground creating a fire hazard.
Don
JohnUlaszek
02-24-2021, 07:41 AM
There are a lot of factors, but i’ve worked with a lot of Tanks Inc. customers and generally don’t have a problem getting them sorted out. I have made suggestions to some of the tank manufacturers based on customer feedback but generally speaking everything I know about the problem is captured in the installation instructions for the IIMUCH vents. And yes, sometimes the tank vent strategy needs to be modified or abandoned.
dhutton
02-24-2021, 09:30 AM
By the way when I said garbage in, garbage out I was not referring to iimuch vents. I was referring to tanks with lousy vent designs.
Don
JohnUlaszek
02-24-2021, 11:03 AM
No worries, I didn’t take it that way.
JohnUlaszek
03-01-2021, 03:33 PM
Don
I’m sorry, I missed this somehow, you may have an unsafe setup there depending on few different factors. Send me an IM or call 888-216-6033 and we’ll figure out what’s going on. I’m confident we can get this sorted out, but Its imperative that you not fill the tank past a few gallons until we figure out what is going on.
