View Full Version : 3 Tilt Steering column, 69-72 Chevelle and a body, 69 Camaro
birdsandbowties
01-25-2021, 06:15 PM
I have three tilts i am working on right now,
one in picture is keyed stock style column for pro touring car, doesn't have lower shifter arm and column is locked in park position , billet levers , this one will be ready in a few days, i just painted it Sunday afternoon and turn signal switches i ordered will be another day , 650.00 shipped and no core required but if you have one or more cores i will certainly buy them
I have two others in paint right now, both for 69 camaro and chevelles,
shaved key tilt, locked in park position billet levers, done in satin black ,I will post pics when its together. 650.00 shipped no core needed
High beam tilt , has dimmer on turn lever, same as other , done in satin black with billet levers, this one is in paint also and will be a few days and i will have pics 650.00 shipped no core needed
I also do column rebuilds and repairs on almost anything with a steering column
Jim 850-382-7125 GMtilt.com183841
CarlC
01-27-2021, 07:49 AM
I can't say enough how good Jim's work is. These columns are light years better than the aftermarlet offerings in every way. After being disheartened with a popular aftermarket column in the Camaro, Jim's column made the fit, feel, feedback, lack of noise, turn signal cam, tilt, etc. the way it should be, so much so the other column went straight into the garbage.
Che70velle
01-27-2021, 01:26 PM
Agree with Carl. Attention to detail in every step of the build puts these columns in front of the line. Buy with confidence here guys and gals!
shelteredchevelle
01-27-2021, 01:55 PM
I too have an aftermarket "popular name" column and am not thrilled with it. Next build I know who to call.
Bygblok
01-28-2021, 08:47 AM
Jim won't let you down on quality and that's a promise. I've had one of his columns in my 70 Camaro for years now and it's perfect!
birdsandbowties
01-30-2021, 10:29 AM
thanks, guys
this column is done and can ship asap184020184021
birdsandbowties
02-01-2021, 07:59 PM
69 standard tilt is sold
mean buzzen half dozen
02-16-2021, 08:37 PM
Just curious, are the tilt columns any longer than a standard column?
t72ss402
02-17-2021, 04:40 PM
Jim, I also have a question. I have a 72 Chevelle and I am looking at installing a push button start switch. I was wondering if one without the key, like from a 68 Chevelle column would fit?
birdsandbowties
02-17-2021, 05:42 PM
if you need a custom length its not a problem, these are plug and play same as original , Jim
- - - Updated - - -
no that column wouldnt work correctly, i do a shaved key tilt for the guys using push button start, same as the others 650.00 shipped
02-17-2021, 07:30 PM
[QUOTE=birdsandbowties;1351830]if you need a custom length its not a problem, these are plug and play same as original , Jim
I was asking if a stock non tilt column for a 69 Camaro is the same length as a tilt column for a 69 Camaro?
birdsandbowties
02-17-2021, 08:16 PM
yes
Rodknock
08-09-2021, 08:52 AM
Do you have any 69 Camaro tilt columns available now?
I have a non-tilt column, I'm not going to use.
ChevelleNV
09-08-2021, 12:29 PM
Jim, I need a tilt column for a third gen camaro (82). prefer a regular lever with no wiper controls or cruise control. you got anything? call me at 844-579-7927 if you can help
Greg
patobusta
09-08-2021, 05:13 PM
Greg
Second this idea... mine is 89 will keep an eye for the reply!
