View Full Version : Ride Tech lower 4 link bar change for more wheel and tire clearance??
builttodrive
01-18-2021, 07:03 PM
I was looking at changing out my current wheels and tires on my 70 Mustang and thinking about going one step wider in the back but I'm only about 3/4" away from my lower ridetech 4 link bar now. If I replaced the lower bar with one that had a different end like a heim joint and could angle the front mount some and sapce it over for a little more room it would help but would it be a worthwhile idea?
183603
183604
130fe
01-18-2021, 11:04 PM
Maybe they have an R-joint bar configuration that might help.
dhutton
01-19-2021, 04:47 AM
I thought they made offset bars for wider tires. Give them a call.
Don
builttodrive
01-19-2021, 05:42 AM
They sell a complete r joint bar kit. When I called them they didn't have much to say about it other than I could possibly try adding R-joint ends to my current rods. Only thing is the R-joint are kinda wide at 1 3/4".
Josh@Ridetech
01-19-2021, 05:46 AM
The smaller end on the bar you currently have is 1 3/4" as well so you wouldn't see anything different there. You could upgrade to the R-Joint bars and then run offset spacers to push the front mount in as close to the frame as possible (and with the articulation they have, you have a little room to play there as well).
builttodrive
01-19-2021, 10:23 AM
Josh, Yeah that is the measurement I took. Can a guy buy just the lower R-joint bars?
Greg
GTOtzel
01-19-2021, 11:28 AM
Worked on a build a few years back with a ridetech 4-link on a 65 Mustang, Project 50/30, for CJ Pony Parts. Josh@Ridetech is familiar. We used these (https://www.ridetech.com/product/large-rod-end-bracket-for-3-wide-rod-end/) and welded them to the inside of the frame rail. It had also been mini-tubbed to fit 20x11 in the rear and a 305 with plenty of room.
Also, the rear link bar mount was moved in where it attached to the axle.
builttodrive
01-19-2021, 07:27 PM
Also mounted narrowed where the axle bracket is attached.
I'll have to visit with Josh more and see what we can come up with. I mini tubbed the car and I have tons of room in the wheel wells but the 4 link bars are my biggest concern. I'm running a 20x10 wheel with a 305 tire now but it would be nice to bring the wheel to an 11" wide and go wider with the tire also. The 305 looks good but a 315 would be better and the wheel wells look like I can get a 325-335 wide tire in there.
