View Full Version : 1966 nova SS pro touring
classiccarcustoms
01-13-2021, 04:47 PM
I am thinking of selling my 1966 Nova project due to shoulder surgery and being laid up for awhile.
1966 Nova real SS. Buyers wife said no. So its back on market.
Real 118 SS
All original metal except 2” cowl metal hood.
Stripped and painted black 3 years ago. No rust or rust repairs.
-Hotrods to Hell front clip (complete sub frame) powder coated, rack and pinion, tubular A-arms, coil overs, Wilwood brakes.
-DSE mini tubs installed.
-Chassis work complete rear 4 link with frame rails and drive line hoop, billet links.
-Fab 9 rear end.
-New 9” center section withb3:55 gears
-Budnik wheels and tires
-Factory bucket seats and center console in great shape. Automatic...
-Ididit tilt column installed and hooked up to rack and pinion.
-Dakota Digital VHX gauges.
-Ring brother billet hood hinges new in box
-front and rear bumpers. Installed.
-black head liner kit. New in box.
-Nurelic power windows. New in the box.
-Vintage Heat and AC kit.
-American auto wire kit.
-Ring brother black billet gas filler. Installed.
-New clutch pedal kit. If u want to go manual.
-New in many box’s. Felt kit, seals, bump stops, bumper bolt kit, outer door handles, outer mirrors, front marker light assemblies, tail light assemblies, lock cylinder kit, bumper brackets, headlight assemblies, headlight bezels, head lights, grill, quarter panel emblems, fender emblems, grill emblems and much more.
-Original rear seat included as well. Will need trimmed due to DSE mini tubs installed.
All original stainless, side glass, vent windows and grill 183397183398183399is included and in good shape.
LS with Vintage A/c front runner kit, 4L60 trans.
Motor and tars instaled.
PSI wiring harness and re flashed ECM.
Ricks tanks, EFi tank with pump and sender, powder coated black, new in the box.
Aluminum LS radiator and electric fans.
LS headers. Installed.
Complete car sound dead.
HID headlights. Installed.
Eddie motor sport billet radio bezel. Installed.
Kenwood radio. Installed.
New /Black kick panels with speakers.
New gauge bezel.
-All suspension installed.
Location San Jose CA.
183400183401183402183403183404
classiccarcustoms
01-16-2021, 08:33 AM
Now installed:
-Vintage AC evaporator and defrost ducks.
-Changed over factory controller from cable to electric for Vintage air.
-New outer door handles.
-New outer mirrors.
-New emblems.
-New rear bumper.
-New billet black Ride-tech gas cap.
183515183516183517183518183519
Bobbywracing
01-16-2021, 12:52 PM
Badass build , I want this one.
classiccarcustoms
01-16-2021, 04:51 PM
Thank you. Its ready for you.
I am going to try and install headlights, grill and a/c condesor and dryer tomorrow.
1moretoy
01-17-2021, 06:26 AM
Im interested and would like to take a look at this. I'm local. And will send you a pm now.
classiccarcustoms
01-17-2021, 08:44 AM
Thank you.
All P.M's replied.
Lonnies Performance
01-17-2021, 03:45 PM
That looks good... how big of a rear tire can you now fit?
classiccarcustoms
01-17-2021, 06:12 PM
Rear rim and tire on it now is a 19x11 with 285-35-19 and I have 2.5” of clearance on the inboard side. Should be able to get 19x12 with 325 tire
Kyle Simpson
01-17-2021, 06:32 PM
Man thats a tiny tire for an 11. 11s are usually running 315s. Are you sure its not a 10 or 9?
jdiesel25
01-23-2021, 05:25 AM
PM me your number if the car is still available.
classiccarcustoms
01-23-2021, 08:21 AM
Good mornin.
Nova is still available.
P.M contact #.
classiccarcustoms
01-24-2021, 07:39 AM
Rocker panel are dirty in picture, factory SS rocker trim holes are all present.
Underside pictures 183752183753183754183755183756
classiccarcustoms
01-28-2021, 09:21 PM
New front and rear bumpers, grill, emblems, headlights, turn-signal assemblies installed.
Also installed front car American auto wire harness all wired in. Changed all bolts for stainless button head hardware.
Also ordered new Eddie motor sport billet hood latch and New port mini wiper motor kit.
I am going to order running gear and Forgelines for it Monday if car isnt sold.
183960183961183962183963183964
daryld
01-30-2021, 08:56 AM
Is the tunnel raised? Are the emblems glued on or are there holes behind the emblems if I was to remove them?
classiccarcustoms
01-30-2021, 11:03 AM
Transmission tunnel is not raised. I am ordering a TKK 5 speed Monday and they do not require any transmission modifications.
All factory emblem holes are present and all emblems are held on by factory mounting.
Firewall is now smoothed by welding up all holes. Ls3 electric gas pedal stand off plate is welded in. manual pedals installed in the now as well.
I also just ordered a LS Be cool aluminum radiator and fans and a 7" power brake booster and Billet master cylinder.
Price will now be a little more for the car. Monday I will be ordering crate LS3 and TKK 5 speed and Forgeline wheels and car will be off the market.184022184023
daryld
01-30-2021, 12:25 PM
Will a 4l65 fit without tunnel mod? I have a stick car and want auto next.
classiccarcustoms
01-30-2021, 02:06 PM
That trans will fit with no tunnel mod's. It gets tight at transmission lines area. But doable.
I have a rebuilt Cam LS1 and 4L65E complete turn key out of my 69 Camaro I can add (not installed) for extra $
I do have the factory 66 nova SS auto shifter, brake pedal, console for this nova.
classiccarcustoms
02-06-2021, 06:26 PM
Got the firewall welded up, smoothed and painted.
New mini wiper motor kit installed.
Dynomat firewall to front seats.
Black felt over dynomat under dash for show car look.
Dash wiring harness and fuse box started.
Sand blasted and painted pedal assembly and re installed.
I have a new 383-700r4 turn key set up and a LS1 4L60 turn key built with cam set up for extra.
184462184463184464184465184466184467
classiccarcustoms
02-14-2021, 10:12 AM
Price has to go up.
Built LS1 with cam
Vintage air billet front runner kit
Rebuilt 4L60
Installed.
Not running yet. 184890
Anthony P
02-14-2021, 01:02 PM
Nice car, good luck with sale.
billviverette
02-27-2021, 07:50 PM
To the top.
Still on the market?
TIA,
Bill
If not, could you give us an update on the build?
classiccarcustoms
02-27-2021, 09:35 PM
Yes, still on the market. Price will be higher than the roller price posted months ago to reflect all the new parts, LS engine and trans and so on.
Update:
Engine and transmission installed.
Billet vintage a/c front runner kit installed.
New Holley 2 piece valve covers installed.
New trans cross member installed.
New Coated headers.
New PSI stand alone harness and flashed ECM.
Vintage A/C
New vintage a/c controller installed.
New Billet Eddie Motor sports billet factory radio bezel for single den radio installed.
classiccarcustoms
03-07-2021, 08:59 PM
Sale fell thru.
1moretoy
03-09-2021, 07:01 PM
What is the new price?
classiccarcustoms
03-09-2021, 07:02 PM
Sorry
SOLD
Back on the market
LSM3
03-09-2021, 10:44 PM
Sorry
SOLD
What diameter were the front wheels? 18s or 19s? Thanks.
classiccarcustoms
03-10-2021, 03:49 PM
18s
New owner doesn't want wheels and tires. They will be for sale.
classiccarcustoms
05-26-2021, 09:03 PM
Hump day bump.
Also ordered new factory 18" Rally wheel and tires. 18x8.5 front with new tires and 18X10 rear with new tires.
shane38
05-27-2021, 05:40 AM
for sale still if so please dm me
classiccarcustoms
05-27-2021, 05:50 AM
Nova is back on the market. My friend(buyer) had something come up.
It has way more parts and way more complete then when I first posted it.
santek
05-27-2021, 12:42 PM
Whats the Price please??
thank you
1moretoy
05-27-2021, 01:42 PM
classiccarcustoms
05-27-2021, 01:46 PM
$68,000
classiccarcustoms
05-28-2021, 11:46 AM
Sold.
